*tie constraint for multiple mesh
S-Y.Chen
Re: *tie constraint for multiple mesh
Post by S-Y.Chen »
-alex- wrote: Tue Feb 09, 2021 8:04 am
S-Y.Chen wrote: Mon Feb 08, 2021 4:56 pm If there are separate boxes for master and slave faces when selecting the faces for tie constraint, and if you can find the nodes/elements on master and slave faces, separately, there should be no confusion for master/slave nodes ?
You are right, but my comments above were about the current situation (bodies with space between).
Currently if you analyse a multi-solides model with contacts on coïncident slave and master faces (lets say Part_Compound with 2 plates) you will not get expected behavior. Slave and master nodes seem to be fused. I assume that's due to single mesh as said in early posts of this thread. If you want I will send an exemple later, no time right now sorry.
BTW I fully agree with your request in order to allow contacts on multi-bodies meshing with coïncident faces with no space between. Would be a huge enhencement.
I believe a lot of persons think these features are important. But how can we make it happen ?
-alex-
Post by -alex- »
S-Y.Chen wrote: Tue Feb 09, 2021 9:02 am But how can we make it happen ?
Ah, good question. By coding I assume... but I have no skills about that so...
If I understand correctly there is 2 strategies:
- improve the current algorithm as @ur said
- implement multi-mesh analysis
I would prefer the second strategy, I assume this would be a convenient way to allocate each slave or master face to the suitable meshed body, efficiently in non ambiguous manner.
IIRC @bernd has an experimental multi-mesh FEM in his branch right?
bernd wrote:ping
BTW how can we access your multi-mesh branch? Just by compiling it?
UR_ wrote: Fri Feb 05, 2021 5:26 pm The reason is FEM's algorithm which decides which node belongs to tied face A and which node belongs to tied face B.
Decision is made by incidence only. :?
We need a much more sophisticated algo. :roll:
Ok, so do you think multi-mesh analysis would ease to know which node belong to the suitable contact face?
Any opinion much appreciated.
davidosterberg
Post by davidosterberg »
S-Y.Chen wrote: Tue Feb 09, 2021 9:02 am I believe a lot of persons think these features are important. But how can we make it happen ?
As I tried to say above. I am planning to implement this. Unless somebody else is already working on it of course.
S-Y.Chen
Post by S-Y.Chen »
davidosterberg wrote: Wed Feb 10, 2021 9:43 pm
Good to hear this. I have been working on some FEM algorithms now and then. So please let me know if I can help.
Jee-Bee
Post by Jee-Bee »
S-Y.Chen
Post by S-Y.Chen »
I have attached an example in the issue report.
Also in this post
https://forum.freecadweb.org/viewtopic.php?f=18&t=71154
