Loading results failed
With any model, I cannot see the results after calculation. However, all the input and output files of the calculation seem correct. ResultMesh and CCX_Results are out of the Analyse. Resultmesh is like FEMMeshGmsh and CCX_Results is empty.
Do you have a solution to find them ?
Thank you very much.
View report :
Custom material directory set by user: does not exist.
choose_material in FEM material task panel:
/usr/share/freecad-daily/Mod/Material/StandardMaterial/Steel-Generic.FCMat
References: empty in MaterialSolid, MaterialSolid
References: Face in ConstraintDisplacement, ConstraintDisplacement
References: Face in ConstraintFixed, ConstraintFixed
Check prerequisites.
Start writing CalculiX input file
Write ccx input file to: /tmp/fcfem_0as4_3sc/FEMMeshGmsh.inp
ConstraintFixed:
Type: Fem::ConstraintFixed, Name: ConstraintFixed
found mesh group for the IDs: ConstraintFixed_Nodes, Type: Node
ConstraintDisplacement:
Type: Fem::ConstraintDisplacement, Name: ConstraintDisplacement
found mesh group for the IDs: ConstraintDisplacement_Nodes, Type: Node
Writing time CalculiX input file: 0.02 seconds
run CalculiX at: /usr/bin/ccx with: /tmp/fcfem_0as4_3sc/FEMMeshGmsh.inp
CalculiX done without error!
We will load the ccx frd and dat result file.
Read ccx results from frd file: /tmp/fcfem_0as4_3sc/FEMMeshGmsh.frd
loading results failed
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.19.
Branch: unknown
Hash: c1ca01b0e79efa44f39ee377bb97517e2fd7debf
Python version: 3.6.9
Qt version: 5.9.5
Locale: French/France (fr_FR)
View report :
ConstraintFixed:
Version: 0.19.
Branch: unknown
Qt version: 5.9.5
- Anneau-1.FCStd
- (120.15 KiB) Downloaded 29 times
Fada de 3D.
Linux Mint
Linux Mint
Re: Loading results failed
- start FreeCAD
- load your file
- delete results
- rerun analysis
- show results
works great here, no problem with your file ...
- load your file
- delete results
- rerun analysis
- show results
would you try to run this code in FreeCAD python konsole and see if the results import fine ...
import feminout.importCcxFrdResults
feminout.importCcxFrdResults.open(FreeCAD.ConfigGet("AppHomePath") + 'Mod/Fem/femtest/data/ccx/cube_static.frd')
@Bernd : thank you for your quick answer.
See the attached pictures of results of ring and cube_static ; picture of warning on the Python Konsole
Thank you for your help.
No change about the ring.
The results import from the cube_static doesn't work.
- Warning on Python Konsole
- Capture du 2020-05-28 17-06-46.png (132.5 KiB) Viewed 2174 times
- Results of cube_static
- Capture du 2020-05-28 17-06-00.png (78.39 KiB) Viewed 2174 times
- Results of ring
- Capture du 2020-05-28 17-01-57.png (65.64 KiB) Viewed 2174 times
Fada de 3D.
Linux Mint
Linux Mint
would you try in FreeCAD python konsole
import matplotlib.pyplot
import tkinter
Good night,
Import of matplotlib.pyplot and tkinter impossible in a new freeCAD window, with or without file. Is it a problem of python version ?
Thank you in advance.
Fada de 3D.
Linux Mint
Linux Mint
it clearly say what is missing on your Linux mint, the package tkinter. Thus
should do the trick
BTW: if you post error messages it would be much more helpful if you would copy them and put them into code tags than making a screen shot. Thus the error message will be found by the search engines and other users with the same problem will find this topic.
sudo apt-get install python3-tk
Thank you Bernd. Now I can see the results.
When I activate the ccx_results, or when I change displacement direction or stress it remains a warning on the report view as follow for example :
Is it dangerous ?
thank you a lot.
File "/usr/share/freecad-daily/Mod/Fem/femviewprovider/view_result_mechanical.py", line 316, in abs_displacement_selected
self.result_selected("Uabs", self.result_obj.DisplacementLengths, "mm")
File "/usr/share/freecad-daily/Mod/Fem/femviewprovider/view_result_mechanical.py", line 533, in result_selected
fig_manager.window.setWindowFlags(QtCore.Qt.WindowStaysOnTopHint) # stay ontop
File "/usr/lib/python3.6/tkinter/__init__.py", line 2101, in __getattr__
return getattr(self.tk, attr)
AttributeError: '_tkinter.tkapp' object has no attribute 'setWindowFlags'
File "/usr/share/freecad-daily/Mod/Fem/femviewprovider/view_result_mechanical.py", line 326, in x_displacement_selected
self.result_selected("U1", res_disp_u1, "mm")
File "/usr/share/freecad-daily/Mod/Fem/femviewprovider/view_result_mechanical.py", line 336, in y_displacement_selected
self.result_selected("U2", res_disp_u2, "mm")
thank you a lot.
Fada de 3D.
Linux Mint
Linux Mint
AFAIK this module is needed for the histogramm only. Give it a try, it might not work. All other should be working in result task panel.
