Elmer electrostatics FEM
HoWil
Re: Elmer electrostatics FEM
Post by HoWil »
Tutorial_6 - Electrostatic equation – Capacitance of two balls_1p0.FCStd
(24.84 KiB) Downloaded 54 times
bernd
Post by bernd »
HoWil wrote: Thu Jun 04, 2020 5:33 pm The change has to be made in the 'Constants' section from
Constants
  Permittivity Of Vacuum = Real 8.8542e-21
End
to
Constants
  Permittivity Of Vacuum = 1 !Real 8.8542e-21
End
really ?!? I do not know elmer sif format. Why should there be still the old value? Or is the ! a comment marker?
HoWil
Post by HoWil »
bernd wrote: Mon Jun 22, 2020 3:57 pm really ?!? I do not know elmer sif format. Why should there be still the old value? Or is the ! a comment marker?
Yes, ! is the comment marker (See page 14 in https://www.nic.funet.fi/pub/sci/physic ... Manual.pdf)
bernd
Post by bernd »
but than should not be the word integer before the 1 ?
bernd
Post by bernd »
or even better
Real 1.0
HoWil
Post by HoWil »
That is correct.
It works without but is totally unambigous with "Real".
raback
Post by raback »
Hi
This is the list of specified keywords in Elmer:
https://github.com/ElmerCSC/elmerfem/bl ... R.KEYWORDS
Not all keywords have made it to the list and their type must be given by the user.
A Real valued keyword can be given value "1" even though it looks suspicious.
In the test the permittivity of vacuum was set to one to make it easier to compare to analytical expressions (with mesh resolution). If you emphasize more the physics here you could well use the real values.
-Peter
bernd
Post by bernd »
@HoWil:
Would you give https://github.com/berndhahnebach/FreeC ... rmittivity a try. Just add constand vacuumpermittivity obj. and change value in property editor. This should change the value in elmer sif file.
bernd
bernd
Post by bernd »
Should the two balls example from this topic be added to standard FreeCAD FEM examples ?
HoWil
Post by HoWil »
bernd wrote: Fri Jun 26, 2020 7:18 am Should the two balls example from this topic be added to standard FreeCAD FEM examples ?
If it works ... for sure :arrow:
Compiling your work...
