for the example "equation_electrostatics_capacitance_two_balls" I get "Error: Missing a mesh object."
If I just add a gmsh-mesh than I get "Error: Result file not found." Please see the output of the Report-view
for "equation_elmer_electrostatics" I get the following output in the Report-view (cutted because of a warning in the forum stating "Your message contains 130659 characters.The maximum number of allowed characters is 60000."):
20:26:08 Traceback (most recent call last):
File "/home/wilfried/bin/FreeCAD/20200715_Freecad_sd/freecad-build/Mod/Fem/femsolver/run.py", line 510, in slotChangedObject
self._checkSolver(obj)
File "/home/wilfried/bin/FreeCAD/20200715_Freecad_sd/freecad-build/Mod/Fem/femsolver/run.py", line 540, in _checkSolver
if analysis == m.analysis and obj == m.solver:
File "/home/wilfried/bin/FreeCAD/20200715_Freecad_sd/freecad-build/Mod/Fem/femsolver/run.py", line 309, in analysis
return self.solver.getParentGroup()
<class 'ReferenceError'>: Cannot access attribute 'getParentGroup' of deleted object
20:26:09 Traceback (most recent call last):
File "/home/wilfried/bin/FreeCAD/20200715_Freecad_sd/freecad-build/Mod/Fem/femsolver/run.py", line 508, in slotChangedObject
self._checkAnalysis(obj)
File "/home/wilfried/bin/FreeCAD/20200715_Freecad_sd/freecad-build/Mod/Fem/femsolver/run.py", line 552, in _checkAnalysis
self._resetAll(obj)
File "/home/wilfried/bin/FreeCAD/20200715_Freecad_sd/freecad-build/Mod/Fem/femsolver/run.py", line 569, in _resetAll
if analysis == m.analysis:
20:26:09 Save FreeCAD file for equation_elmer_electrostatics_elmer analysis to /tmp/FEM_examples/equation_elmer_electrostatics_elmer.FCStd
.20:26:09 The SI unit schema m/kg/s is used. Elmer sif-file writing is done in SI-units.
20:26:09 'Coordinate Scaling = Real 0.001' was inserted into the solver input file.
20:26:09 'Coordinate Scaling Revert = Logical True' was inserted into the solver input file.
20:26:09 ElementDimension: 3
20:26:09 /home/wilfried/bin/gmsh/gmsh-4.4.1-Linux64/bin/gmsh
20:26:09 Solver binary path: /home/wilfried/bin/ElmerFEM_compile/20200625-elmer-dev-coordinate-scaling-revert/elmer-install/bin/ElmerGrid
20:26:10 Solver binary path: /home/wilfried/bin/ElmerFEM_compile/20200625-elmer-dev-coordinate-scaling-revert/elmer-install/bin/ElmerSolver_mpi
20:26:11 Traceback (most recent call last):
After that I checkt the capacitance value which 2.15100E-10 F .... see also the solver output:
After swichting of "Calculate Capacitance Matrix" we get the correct value for the force:
