If I run the the simulation I get a warning "Warning: Ignored constraint ConstantVacuumPermittivity." while the constant value is exported (see below the exported .sif).
The value in the Data-Tab of the Combo-View is given as with "s^4*A^2/(mm^3*kg)". We should switch here to m-based units to avoid confusions. Such values are usually given in ISO/meter-based units. We also use Volts for the potential. Nevertheless the input dialogue accepts the input of units to "F/m" or "s^4*A^2/(m^3*kg)" which is automatically changed to "s^4*A^2/(mm^3*kg)" "F/m" would be good as standard unit (See also https://en.wikipedia.org/wiki/Vacuum_permittivity).
a value of 1 is exported as 0.9999999999999999 ... this is in my opinion a python-limitation !?
If you can change the two minor things above than the attached model is ready for the examples. Thank you very much!!!
Next stop ISO units .
Screenshot from 2020-06-28 08-57-16.png (339.79 KiB) Viewed 2060 times
Screenshot from 2020-06-28 09-15-54.png (357.83 KiB) Viewed 2060 times
Check Keywords Warn
Header
Mesh DB "."
End
Solver 1
Bubbles = Logical False
Calculate Capacitance Matrix = Logical True
Calculate Electric Energy = Logical True
Calculate Electric Field = Logical True
Calculate Surface Charge = Logical False
Displace mesh = Logical False
Equation = String "Stat Elec Solver"
Exec Solver = String "Always"
Linear System Abort Not Converged = Logical False
Linear System Convergence Tolerance = Real 1e-08
Linear System Iterative Method = String "BiCGStab"
Linear System Max Iterations = Integer 500
Linear System Precondition Recompute = Integer 1
Linear System Preconditioning = String "ILU0"
Linear System Residual Output = Integer 1
Linear System Solver = String "Iterative"
Optimize Bandwidth = Logical True
Procedure = File "StatElecSolve" "StatElecSolver"
Stabilize = Logical True
Steady State Convergence Tolerance = Real 1e-05
Variable = String "Potential"
Variable DOFs = Integer 1
End
Simulation
BDF Order = Integer 1
Coordinate Mapping(3) = Integer 1 2 3
Coordinate System = String "Cartesian 3D"
Output Intervals = Integer 1
Simulation Type = String "Steady state"
Steady State Max Iterations = Integer 1
Steady State Min Iterations = Integer 0
Timestepping Method = String "BDF"
Use Mesh Names = Logical True
End
Constants
Permittivity Of Vacuum = Real 0.9999999999999999
End
Body 1
Equation = Integer 1
Material = Integer 1
Name = String "Solid1"
End
Material 1
Relative Permittivity = Real 1.0
End
Equation 1
Active Solvers(2) = Integer 1 2
End
Solver 2
Equation = String "ResultOutput"
Exec Solver = String "After simulation"
Output File Name = File "case"
Procedure = File "ResultOutputSolve" "ResultOutputSolver"
Vtu Format = Logical True
End
Boundary Condition 1
Electric Infinity BC = Logical True
Name = String "Face1"
End
Boundary Condition 2
Capacitance Body = Integer 1
Name = String "Face2"
End
Boundary Condition 3
Capacitance Body = Integer 2
Name = String "Face3"
End
! If you get a mm-based capacitance C12 of 1.46980E-17 (F-mm-based) than the permittivity was not set right!
If C12 yields mm-based 1.66000E-06 (F-mm-based) than everything worked correctly.
import quantities as pq
C_mm = 1.66000E-06 * (pq.A**2 * pq.s**4 / (pq.kg * pq.mm**2))
print("Capacity in F : " + str(C_mm.rescale(pq.F)))
This gives an: Capacity in F : 1.66 F
really? Have you used latest branch? Not here. Would you print all output from report console?
This is for sure another git related issue .
Not sure if Git and I will ever be good friends .
Will erase everything and start from scratch.
AFAIK a task panel would be needed to explicit use a user defined unit.
HoWil wrote: ↑Sun Jun 28, 2020 7:23 am
[*] a value of 1 is exported as 0.9999999999999999 ... this is in my opinion a python-limitation !?
[/list]
noted this too, played a bit, but I do not want to change to much in Markus his constant implementation code as it may make problems with other constants. We may need to tackle this down later on.
Would it be possible to test the two Elmer electrostatic examples from new GSoC development? Since we do heavy testing it is best to post all about the electrostatic examples here in this topic. They can be easily set up by the new fem examples gui.
Nice to see it evolving.
Is it possible to merge it into 0.19? Currently I am not able to compile a lot and It would be much much easier to test it in dev-branch.
If it is not possible than it will take 2 to 3 days until I can test .
Thanks again for your work...
