PR #6761 -- Part workbench Link support
TheMarkster
Post by TheMarkster »
https://github.com/FreeCAD/FreeCAD/pull/6761
This file crashes with this PR:
To reproduce, open the file and refresh.
sweep_test_crash.FCStd
(11.85 KiB) Downloaded 190 times
How to prevent the crash?
This file results in a ruled surface that is incorrectly placed (except because of a new property I added it doesn't happen unless the new property "Reset Placement" is set to True).
ruled_surface.FCStd
(6.78 KiB) Downloaded 155 times
Would it be better to remove the workaround code entirely? I think it's better to have the property in case it is still needed in some situations. Is there a better way to handle this situation?
Note: setting the property back to false does not reset the placement. I didn't want to change the placement in case the user has moved it.
This PR is in response to this post:
https://forum.freecadweb.org/viewtopic.php?f=3&t=67960
Basically, it adds support for App::Link sublinks by replacing calls to Part::TopoShape::getSubShape() with Part::Feature::getTopoShape(docobj, subelementname, true /*need subelement*/).getShape(). Both functions return the TopoDS_Shape of the subshape, but getTopoShape() handles the case where docobj is App::Link sublink.
openBrain
Re: PR #6761 -- Part workbench Link support
Post by openBrain »
TheMarkster wrote: Sun Apr 17, 2022 8:05 pm This file crashes with this PR:
According my tests, the file also crashes without the PR. It crashes in OCC actually.
There is no reason why this PR should be delayed of the crash because it's not due to it. ;)
I looked at the PR but lack information.
But yes, better avoid a workaround if possible. Especially here it looks like a workaround on another one, which doesn't smell good generally. ;)
Could you give some details about the problem ? Implied code lines, and what they do or are intended to (functionally) do ?
TheMarkster
openBrain wrote: Mon May 09, 2022 4:54 pm
https://github.com/FreeCAD/FreeCAD/blob ... s.cpp#L244
This is where the placement is getting reset. The new property will default to false, so this workaround does not get applied. But it can be set to True for those cases where it might still be needed. But if the workaround is no longer needed then it could be better to just remove it.
