Best way to cancel pull request #453
dan-miel
Post by dan-miel »
I need to learn how to use github, what is the best way to cancel the #453 pull request that I is messed up?
Side question: What is a Pep8 fix?
Thanks
Dan Miel
openBrain
Re: Best way to cancel pull request #453
Post by openBrain »
dan-miel wrote: Wed Mar 16, 2022 2:21 pm I need to learn how to use github, what is the best way to cancel the #453 pull request that I is messed up?
Your PR number should have an issue.
Just close your PR.
PEP8 is what defines guidelines for Python coding.
