PR #6353 improve Link support in Part Workbench
TheMarkster
Post by TheMarkster »
https://github.com/FreeCAD/FreeCAD/pull/6353
This needs to be built and tested because it basically covers changes to most of Part workbench:
Loft
Sweep
Extrude
Revolution
Reversed
Mirror
Offset2D
Offset3D
CheckGeometry (checks the linked shape)
Ruled Surface
Cross-sections
Thickness
all should now support using Links.
TheMarkster
Re: PR #6353 improve Link support in Part Workbench
This has been merged. Needless to say, such a big PR needs lots of testing, so any issues can be addressed before the new release.
