The PR was merged.
@davidosterberg, by changing the code in https://github.com/FreeCAD/FreeCAD/blob ... Helper.cpp you can try out your solution. It will affect Part and PartDesign.
[merged] PR #5357 - add feature to create tapered Pads / Pockets
- adrianinsaval
Re: PR #5357 - add feature to create tapered Pads / Pockets
Hello uwe, please look at this example, the same sketch (copy pasted) can be extruded with taper without issues in Part but not in Part Design, even without taper, I think the sketch validation is still usign whatever rules applied to the old pad algorithm but your new algorithm can actually handle this kind of nested shapes.uwestoehr wrote:
Oh and let's not forget that the error message is absolutely useless:
14:38:05 Recompute failed! Please check report view.
in a popup but once the pad is already created and you change the sketch to have a shape like this you only get that shitty message in report view, nothing about the face.Failed to validate broken face
- extrudeExample.zip.fcstd
- (82.53 KiB) Downloaded 128 times
- Shalmeneser
Re: [merged] PR #5357 - add feature to create tapered Pads / Pockets
In PartDesign, you cannot draw a line inside a line inside a line.
Re: project: Making Part Extrude taking care of inner structure
Hi, hope you and your familly are fine. It seems you're offline since a while. May I ask you if you made some progress in order to get linear elements on ruled shapes (ruled, loft, sweep, tapered) when input edges are coplanar?davidosterberg wrote: ↑Mon Jan 31, 2022 7:26 pmWill work on this in 1-2 weeks when I get my brand new laptop. Unfortunately my 1.5 year old son managed to smash my old development laptop when playing
Thanks for your kind attention.
