[Merged] PR #3923 Sketcher: Fix merged constraint preselection bug
Hello. There is bug in sketcher that does not allow you to preselect constraints if you increase zoom. See https://imgur.com/a/1WXSmNQ. It only happens if constraint icons are close enough to each other so that they get merged into a single icon. I've looked through the tracker and didn't find anything similar to this. Solution is pretty simple but it took a few weeks to find it.
Re: [PR #3923] Sketcher: Fix merged constraint preselection bug
Please add the about info of the FC version you can recreate this bug on
I think you can recreate it on any version. I've checked 0.18 and the latest build of 0.19
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.19.22614 (Git)
Build type: Debug
Hash: 9c20ce05edd82d6a76f48c1948beab7098927ed5
Python version: 3.6.9
Qt version: 5.9.5
Build type: Debug
Qt version: 5.9.5
I can only confirm half of this issue: if an element has multiple constraints, it is not possible to select one of them. There should be a trycker entry for this.
This behaviour doesn't change here even I zoom in or out.
OS: macOS 10.15
Version: 0.19.22611 (Git)
Hash: 7eeec7a5990cc786723225ca8de16ca3186545b3
Python version: 3.8.5
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
OS: macOS 10.15
Qt version: 5.12.9
OCC version: 7.4.0
In the file https://github.com/FreeCAD/FreeCAD/blob ... Sketch.cpp function ViewProviderSketch::detectPreselectionConstr there is a commented line that would print a lot of relevant variables. You can see that if you increase zoom, the icon position coordinates become huge. For example, my output for low zoom
high zoom
Here
The output will only be printed when cursor is moving over one of the merged icons.
Abs(-9.989820,-0.095376),Trans(1.250000,0.000000),Coords(245,144),iCoords(249.608734,159.353897),icon(6,34),isize(23,35),boundingbox([0,19],[15,34])
Abs(-9.989820,-0.095376),Trans(1.250000,0.000000),Coords(340,165),iCoords(244433.703125,174.197723),icon(-244082,28),isize(23,35),boundingbox([0,19],[15,34])
- Abs - Absolute position of the icon on sketch plane
- Trans - relative position of the icon on sketch plane
- Coords - cursor coordinates on the screen
- iCoords - icon coordinates on the screen
- icon - position of the cursor relative to the position of the icon
