PR #3669: Sketcher: fix crash, when cloning element having a non-driving distance, radius, diameter or angle constraint
tom
Post by tom »
this PR fixes issue #4393, which was discussed here. The PR contains a detailed description of the root cause of the crash.
BR Tom
