Unnamedの使い方を教えて下さい。
Japanese forum
mrrclb48z
Unnamedの使い方を教えて下さい。
Post by mrrclb48z »
Unnamedを変更するとうごきません。
参考になるヘルプがあれば、教えてください。
import FreeCAD
import Part
import DraftTools
import Draft
import Mesh
def myTetrahedron(P1x,P1y,P1z,P2x,P2y,P2z,P3x,P3y,P3z,P4x,P4y,P4z):
    xDummy=0
    yDummy=0
    zDummy=0
    a =[[xDummy,yDummy,zDummy],  #dummy
        [P1x,P1y,P1z],
        [P2x,P2y,P2z],
        [P3x,P3y,P3z],
        [P4x,P4y,P4z]]
    m1 = Mesh.Mesh([a[1],a[2],a[3]])
    m2 = Mesh.Mesh([a[1],a[2],a[4]])
    m3 = Mesh.Mesh([a[2],a[3],a[4]])
    m4 = Mesh.Mesh([a[3],a[1],a[4]])
    mesh=Mesh.Mesh()
    mesh.addMesh(m1)
    mesh.addMesh(m2)
    mesh.addMesh(m3)
    mesh.addMesh(m4)
    shape = Part.Shape()
    shape.makeShapeFromMesh(mesh.Topology,0.05)
    solid = Part.makeSolid(shape).removeSplitter()
    myWedgei='myTetrahedron_'+'x' + str(P1x) + 'y' + str(P1y)+ 'z' + str(P1z)
    f = App.activeDocument().addObject("Part::Feature",myWedgei)
    f.Shape = solid
    FreeCADGui.getDocument('Unnamed').getObject('myTetrahedron_x0_0y0_0z5_0').ShapeColor = (1.00,1.00,0.50)
    target_object=App.ActiveDocument.getObjectsByLabel("myTetrahedron_x0_0y0_0z5_0")[0]
    myVolume=target_object.Shape.Volume
    myTxt_XYZ(0,0,0,"{:.3f}".format(myVolume)+'cm3')
def myCube(mySize):
    App.ActiveDocument.addObject("Part::Box","Box")
    App.getDocument('Unnamed').Box.Length=mySize
    App.getDocument('Unnamed').Box.Width=mySize
    App.getDocument('Unnamed').Box.Height=mySize
    App.getDocument('Unnamed').Box.Placement=App.Placement(App.Vector(0.00,0.00,0.00),App.Rotation(App.Vector(0.00,0.00,1.00),0.00))
    FreeCADGui.getDocument('Unnamed').getObject('Box').Transparency = 100
def myTxt_XYZ(P5x,P5y,P5z,myWedgei):
    p5 = FreeCAD.Vector(P5x,P5y,P5z)
    myText = Draft.makeText(myWedgei,p5)
    myText.Label = myWedgei
    FreeCADGui.ActiveDocument.ActiveObject.FontSize = '0.7 mm'
# [(0,0,5),(6,0,2),(6,6,4),(0,6,0)]
P1x,P1y,P1z=0.0,0.0,5.0
P2x,P2y,P2z=6.0,0.0,2.0
P3x,P3y,P3z=6.0,6.0,4.0
P4x,P4y,P4z=0.0,6.0,0.0
myTxt_XYZ(P1x,P1y,P1z,'x' + str(P1x) + 'y' + str(P1y)+ 'z' + str(P1z))
myTxt_XYZ(P2x,P2y,P2z,'x' + str(P2x) + 'y' + str(P2y)+ 'z' + str(P2z))
myTxt_XYZ(P3x,P3y,P3z,'x' + str(P3x) + 'y' + str(P3y)+ 'z' + str(P3z))
myTxt_XYZ(P4x,P4y,P4z,'x' + str(P4x) + 'y' + str(P4y)+ 'z' + str(P4z))
myCube(6.0)
Gui.activeDocument().activeView().viewAxonometric()
Gui.SendMsgToActiveView("ViewFit")
h.tsubota
Re: Unnamedの使い方を教えて下さい。
Post by h.tsubota »
Unnamed はドキュメントの名前なので、Unnamed が無くても動くようにしたければ例えば activeDocument() でドキュメントを取るよう変更にすればよいのではないでしょうか。
Windows 版の FreeCAD 0.19.1 では以下のようにすれば任意のアクティブなドキュメントでエラー無く動作しました。
import FreeCAD
import Part
import DraftTools
import Draft
import Mesh
    doc = App.activeDocument()
    gui_doc=Gui.activeDocument()
    xDummy=0
    yDummy=0
    zDummy=0
        [P1x,P1y,P1z],
        [P2x,P2y,P2z],
        [P3x,P3y,P3z],
        [P4x,P4y,P4z]]
    mesh=Mesh.Mesh()
    mesh.addMesh(m1)
    mesh.addMesh(m2)
    mesh.addMesh(m3)
    mesh.addMesh(m4)
    f = doc.addObject("Part::Feature",myWedgei)
    f.Shape = solid
    gui_doc.getObject('myTetrahedron_x0_0y0_0z5_0').ShapeColor = (1.00,1.00,0.50)
    target_object=doc.getObjectsByLabel("myTetrahedron_x0_0y0_0z5_0")[0]
def myCube(mySize):
    doc.addObject("Part::Box","Box")
    doc.Box.Length=mySize
    doc.Box.Width=mySize
    doc.Box.Height=mySize
    doc.Box.Placement=App.Placement(App.Vector(0.00,0.00,0.00),App.Rotation(App.Vector(0.00,0.00,1.00),0.00))
    gui_doc.getObject('Box').Transparency = 100
myCube(6.0)
mrrclb48z
Post by mrrclb48z »
ありがとうございました。
①(オリジナルポスト)「【今年の1問】 2021年開成中-三角すいの体積」を参考にWolframAlphaとonline sympyとFreeCAD でやってみた。
https://qiita.com/mrrclb48z/items/159ea13c0fb80b3a8f0d
②winmergeしました。
(タイトル)Qiita上にhtm文の投稿方法を教えて下さい。
https://qiita.com/mrrclb48z/questions/3 ... 672364865a
