Adaptive milling operation
Hello. When i try setting spesific startpoint for milling operation there is no true button where i can activate startpoint
Re: Adaptive milling operation
I do not believe that Adaptive allows a user-specified start point. There are a few settings such as inside/outside and clear from inside, but mostly the path is fully automatic.
Gene
Gene
Can anyone fix that proplem?
Why is it a problem?
Please explain your requirement a bit more. There may be other ways to solve the issue you are seeing.
Gene
Gene
