SetupSheet combo view editing
Svet
Post by Svet »
Hello.
Have a following problem when opening setup sheet for edit (double click on it)
OS: Windows 10 (10.0)
Version: 0.21.29485 (Git)
Hash: a236ca843fdd6674afb6d7ed1454fbd3b547f5ea
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
  * CubeMenu
  * CurvedShapes
  * Curves 0.4.4
  * Defeaturing
  * ExtMan
  * fasteners
  * Glass
  * IconThemes
  * kicadStepUpMod
  * lattice2
  * Manipulator
  * Marz 0.0.26-alpha
  * PieMenu
  * Silk 1.0.0
  * workfeature-macro
Also there is an error during postprocess:
22:34:09  Running the Python command 'Path_Post' failed:
  File "C:\Projects\Portable software\FreeCAD_weekly-builds-29485-2022-07-17-conda-Windows-x86_64-py38\Mod\Path\PathScripts\PathPost.py", line 575, in Activated
    finalgcode += gcode
can only concatenate str (not "NoneType") to str
mlampert
Re: SetupSheet combo view editing
Post by mlampert »
What's the problem with the setup sheet?
Svet
Post by Svet »
As it shown on a screenshot - It's unreal to see what is inside or edit it. All lists collapsed. For example how it should look like (link branch):
Version: 2022.709.26244 +5001 (Git)
Branch: LinkDaily
Hash: 096210d21183e9dfdc3b25777760bfb6c00a210b
Python version: 3.9.13
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
GeneFC
Post by GeneFC »
I have exactly the same version of FreeCAD (not RT), and the SetupSheet looks normal. It looks just like the RT version you posted above.
It is possible that your configuration file (user.cfg) is borked. To test, save your user.cfg file and remove it from its current location. Then start FreeCAD and see if the problem is still there. You can easily restore your original user.cfg if that is not the cause.
Gene
