STEP file not visible geometry in Path
Routerworks
Post by Routerworks »
I'm trying to develop my use of Freecad Path for cnc 3D milling. I have been doing a lot reading regarding file formats. To make a long story short, I have been concentrating on converting mesh files for milling. I'm pretty comfortable with milling shapes I designed in Freecad CAD. My understanding to date is that a Mesh has to be reduced to number of triangles in the neighborhood of 50,000. then converted to a solid making sure the geometry is closed. Then exported as a STEP file. Then brought back into Freecad by opening (not importing, takes forever).
When I do this the geometry is seen in "Setup" but when I choose "Surface 3D mill" it doesn't see it. Needless to say I have been over this at least a 100 times. By reducing the facets to 12,500 it made a big difference in getting the file to open up. However no luck in developing a too path.
Any help would be greatly appreciated.
Tried to attach it but still says the STEP file is too big.
Thanks
Routerworks
Re: STEP file not visible geometry in Path
Here are my system details:
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * Assembly4
  * BOLTSFC
  * Curves 0.3.0
  * Estimate 0.1.2
  * ExplodedAssembly
  * fasteners
  * fcgear
  * kicadStepUpMod
  * lattice2
  * nurbs
  * pcb
  * POV-Ray-Rendering
  * python27_x64-ocl (1)
  * Render
  * sheetmetal
  * workfeature
  * workfeature-macro
jescombe
Post by jescombe »
Hi, doesn't exactly answer your question, but this is what I do when creating path jobs from (for instance) STL mesh files.. Might be something useful in there?
https://wiki.freecadweb.org/FreeCAD_and_Mesh_Import
Joyas
Post by Joyas »
I have the same problem, the STL files have been generated in Catia V5 (CGM) and cylinders have two halves (seams). If you want I can upload here a file.
Estudié ingeniería técnica industrial en España y sólo me ha servido para estar en el paro, no me contratan porque no tengo experiencia, y no tengo experiencia porque no me contratan. No debí estudiar esa carrera.
