Problems with path and Python 3.6
Founder
Re: Problems with path and Python 3.6
Post by wmayer »
surprising to read a sentence in French, I've put the GUI in English.
That's a message coming from your OS, not the application. Does your latest FreeCAD package have the Import.so module?
david69
Post by david69 »
wmayer wrote: Sun Jul 17, 2022 10:43 am That's a message coming from your OS, not the application
so the OS can "communicate" and prints in FreeCAD report view, I didn't know.
wmayer wrote: Sun Jul 17, 2022 10:43 am Does your latest FreeCAD package have the Import.so module?
Python and me, we live in a different universe. I've looked for some hints on the net and I did that in a console:
dvd@dvd:~$ python -c "Import.so"
NameError: name 'Import' is not defined
is the checking correct?
david69
Post by david69 »
Catfish is my friend:
Capture du 2022-07-17 17-50-09.png (9.57 KiB) Viewed 855 times
so yes, since yesterday, I've got this module.
Founder
Post by wmayer »
david69 wrote: Sun Jul 17, 2022 3:20 pm so the OS can "communicate" and prints in FreeCAD report view, I didn't know.
The .so file is a shared library that couldn't be loaded (via dlopen) for some reason and the error that comes from the OS is forwarded to Python. And since we (can) redirect Python stdout & stderr messages it appears inside FreeCAD.
This won't work. First, of all you must make sure to run Python3 (but the call of python probably starts Python2), then you must add the path to FreeCAD.so to your sys.path. Then you can import FreeCAD and afterwards you can import Import.
python3
import sys
sys.path.append("/usr/lib/freecad-daily-python3/lib")
import FreeCAD
import Import
david69
Post by david69 »
in a console of my OS, here is what I'm doing:
dvd@dvd:~$ python3
Python 3.6.9 (default, Jun 29 2022, 11:45:57)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import sys
>>> import FreeCAD
>>> import Import
I'm learning my OS has two Python versions, a 2.7.17 and a 3.6.9 and I understand why you ask to typewrite first of all python3
once done, I launch FreeCAD and select Path workbench and but still the same previous msg in the report view.
22:16:31 Import.so: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type
22:16:31 Traceback (most recent call last):
File "<string>", line 62, in Initialize
File "/usr/share/freecad-daily/Mod/Path/PathScripts/PathPreferencesPathJob.py", line 24, in <module>
import Path
it seems either I did something wrong or it is useless.
manup
Post by manup »
Hi, I do experience the same issue as described by @david69, here's what I can share about it when I try to use Path:
$ python3
Python 3.10.6 (main, Aug 10 2022, 11:40:04) [GCC 11.3.0] on linux
>>> import sys
>>> import FreeCAD
>>> import Import
$ freecad-daily
FreeCAD 0.21, Libs: 0.21R
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2022
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
User path has changed to /home/manu/.local/share/FreeCAD/. Please move user modules and macros
connect failed: Aucun fichier ou dossier de ce type
  File "/usr/lib/python3/dist-packages/shiboken2/files.dir/shibokensupport/__feature__.py", line 142, in _import
    import Path
So, same question here: what's wrong on this Ubuntu 22.04 system running python 3.10.6, did I miss something, what can be done to make it work?
manu
