post: KineticNCBeamicon2(/home/drip/FreeCAD/ExtrusionCutting/demo.nc, )
09:19:26 Show editor = 1
09:19:26 postprocessing...
09:19:26 Running the Python command 'Path_Post' failed:
File "/tmp/.mount_FreeCAzgsvit/usr/Mod/Path/PathScripts/PathPost.py", line 437, in Activated
(fail, rc, filename) = self.exportObjectsWith(slist, job)
File "/tmp/.mount_FreeCAzgsvit/usr/Mod/Path/PathScripts/PathPost.py", line 216, in exportObjectsWith
gcode = processor.export(objs, filename, postArgs)
File "/tmp/.mount_FreeCAzgsvit/usr/Mod/Path/PathScripts/PathPostProcessor.py", line 105, in export
return self.script.export(obj, filename, args)
File "/tmp/.mount_FreeCAzgsvit/usr/Mod/Path/PathScripts/post/KineticNCBeamicon2_post.py", line 227, in export
job = PathUtils.findParentJob(obj)
File "/tmp/.mount_FreeCAzgsvit/usr/Mod/Path/PathScripts/PathUtils.py", line 405, in findParentJob
for i in obj.InList:
'_TempObject' object has no attribute 'InList'
- Open part design bench
- Square sketch in XY
- 20mm pad into Z
- Open the Path bench
- Create a new job with default options
- Update setup sheet to fill in speeds and feeds
- Update tool to fill in speeds and feeds
- Create profile operation on entire model
- Path -> Post Process, enter file name, hit ok
- View error message in console
OS: Ubuntu 20.04.4 LTS (ubuntu:GNOME/ubuntu)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
