Drilling op touches stock on horizontal move on LinuxCNC
agren
Post by agren »
Hi all,
I think I've found a bug where the drilling operation is touching the stock while moving horizontally between holes. Technically it's seems to be positioned 0 mm from the top of the stock but neither my stock nor my table is perfectly level.
FreeCAD renders a lift to Safe Height as I would expect.
Camotics lift to Safe Height.
LinuxCNC does not lift to Safe Height.
The gcode is generated by the linuxcnc post processor.
A workaround is to manually set Start Depth for the operation to something above the stock.
Anyone noticed the same thing?
FreeCAD:
Camotics:
LinuxCNC (top of stock at Z=0):
OS: Ubuntu 20.04.4 LTS (MATE/mate)
Version: 0.20.
Branch: unknown
Hash: 134fa8b7ea5000ae648afcbe9b36c37a32974e89
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, OCC 7.5.2
path-not-lifting-between-drill-holes.ngc.txt
(720 Bytes) Downloaded 11 times
path-not-lifting-between-drill-holes.FCStd
(22.72 KiB) Downloaded 15 times
agren
Re: Drilling op touches stock on horizontal move on LinuxCNC
Post by agren »
The offending gcode can be seen here. The top of my stock is at Z=0 and my safe height is at Z=3.
G81...R0.000 in G99 mode tells LinuxCNC to go to Z=0 when the drill cycle is done.
Line 26-30 (Drilling the first hole):
G90
G99
G0 X10.000 Y10.000
G0 Z3.000
G81 X10.000 Y10.000 Z-10.000 F100.000 R0.000
G0 X20.000 Y10.000
G0 Z3.000
agren
Post by agren »
Suggested fix here.
It adds a retractheight argument to drill_generator.generate().
LinuxCNC lifts to Retract Height (Z=3) after fix:
sliptonic
Post by sliptonic »
I think the default value for retractHeight should be None. Then the generator should check if it's none and use startpoint.z if so. Otherwise use the explicitly passed retractHeight.
Why don't you create a draft PR for the change and we'll go from there.
I would like to make the generators as thoroughly tested as possible. That's why they're structured as pure functions. So please add additional tests to
https://github.com/FreeCAD/FreeCAD/blob ... nerator.py
agren
Post by agren »
Sounds like a plan!
agren
Post by agren »
Draft pull-request here for those interested.
sliptonic
Post by sliptonic »
I think this looks great. I don't see any problems but let's see if we can get some others testing as well.
BTW, This thread is a master class on how to do it:
Excellent, clear description ... check
Pictures... check
FreeCAD info... check
Attached project file... check
Attached output... check
Suggested fix... check
Draft PR... check
Unit tests.... check
Brilliant!
