dear all,
I have to mill the inner seat of the attached model, how can I do?
Thank you
D
Help: How do I mill the internal seat of this model?
- SedeProva.FCStd
- (38.34 KiB) Downloaded 32 times
Reason: Updated title
Re: Help: How do I mill the internal seat of this model?
Please add full About info when asking for help.
Lots of variables left to the imagination. This is one possible way to do it with just a 1mm end mill. I would end up editing some of the code generated to make the process faster since the last pocket cut is mostly air cuts. Here is your file with 3 pockets.
- Untitled.png (128.46 KiB) Viewed 1215 times
I too would have liked to see a bit more from dino, at least a job and a pocket.
Nice idea with adding the bottom face , although it is never reached; I will keep that in mind.I would end up editing some of the code generated to make the process faster since the last pocket cut is mostly air cuts. Here is your file with 3 pockets.SedeProva.FCStd
If you divide the final pocket in two and add extensions, it can be done without manual editing:
- SedeProva_cb.FCStd
- (70.54 KiB) Downloaded 24 times
Well that is a nice trick gonna put that in my bag of tricks. I tried a profile with just the edges and didn't workout. I am not sure why sometimes just selecting edges works out and sometimes it does not since we do have the ability to select inside or outside in the profile options. I didn't spend anytime reversing the model to get only what is needed to do a path. That is really slick ChrisB my hat is off to you. I agree a little more effort on the post would have been nice.If you divide the final pocket in two and add extensions, it can be done without manual editing:
I have tried to do it using pockets but it not works for me, I'm using FC0.19 and path mills only the biggest inner seat
If try to load "SedeProva_cb" have a lot of errors...
Where can i download FC0.20?
Thanks a lot, and sorry for the little information
OS: Windows 10 Version 2009
Version: 0.19.24267 +148 (Git)
Branch: Branch_0.19.4
Hash: 476ecf091941bead59b14e44afa6064d5a66afa3
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Locale: Italian/Italy (it_IT)
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
- Errors.txt
- (2.02 KiB) Downloaded 20 times
For Path: try 0.20.
Aside: I looking forward towards the v0.20 release and then hopefully we can have more minor releases.
