6040 CNC Path Macro for fast text engraving plus video
CoderMusashi
Post by CoderMusashi »
I am posting this here first and the video link in the tutorial section of the forum. Hope you enjoy the video and the macro that goes with it. I made it for a new FreeCAD and 6040 user. Before running the macro change your font location in the macro.. I commented out what a windows path might look like..
The link to the video https://youtu.be/DsRkUlEwouY
The Macro
import Part
import Draft
import Sketcher
doc = App.newDocument("Unnamed")
#Create our table bed Sketch
App.activeDocument().addObject('Sketcher::SketchObject', 'Sketch')
App.activeDocument().Sketch.Placement = App.Placement(App.Vector(0.000000, 0.000000, 0.000000), App.Rotation(0.000000, 0.000000, 0.000000, 1.000000))
App.activeDocument().Sketch.MapMode = "Deactivated"
geoList = []
geoList.append(Part.LineSegment(App.Vector(0.000000,0.000000,0),App.Vector(19,0.000000,0)))
geoList.append(Part.LineSegment(App.Vector(19,0.000000,0),App.Vector(19,30,0)))
geoList.append(Part.LineSegment(App.Vector(19,30,0),App.Vector(0.000000,30,0)))
geoList.append(Part.LineSegment(App.Vector(0.000000,30,0),App.Vector(0.000000,0.000000,0)))
App.getDocument('Unnamed').getObject('Sketch').addGeometry(geoList,False)
conList = []
conList.append(Sketcher.Constraint('Coincident',0,2,1,1))
conList.append(Sketcher.Constraint('Coincident',1,2,2,1))
conList.append(Sketcher.Constraint('Coincident',2,2,3,1))
conList.append(Sketcher.Constraint('Coincident',3,2,0,1))
conList.append(Sketcher.Constraint('Horizontal',0))
conList.append(Sketcher.Constraint('Horizontal',2))
conList.append(Sketcher.Constraint('Vertical',1))
conList.append(Sketcher.Constraint('Vertical',3))
App.getDocument('Unnamed').getObject('Sketch').addConstraint(conList)
del geoList, conList
App.getDocument('Unnamed').getObject('Sketch').addConstraint(Sketcher.Constraint('Coincident',0,1,-1,1))
App.getDocument('Unnamed').getObject('Sketch').addConstraint(Sketcher.Constraint('DistanceX',2,2,2,1,19))
App.getDocument('Unnamed').getObject('Sketch').setDatum(9,App.Units.Quantity('19 in'))
App.getDocument('Unnamed').getObject('Sketch').addConstraint(Sketcher.Constraint('DistanceY',3,2,3,1,30))
App.getDocument('Unnamed').getObject('Sketch').setDatum(10,App.Units.Quantity('30 in'))
#End of Table Bed Sketch
#Create Text and move it
ourstring = "Go Get The $"
#for windows operating systems use
#FontFile="C:/Windows/Fonts/ANTQUAB.TTF"
#in the next line of code replacing /usr/share
ss=Draft.make_shapestring(String=ourstring , FontFile="/usr/share/fonts/truetype/padauk/Padauk-Regular.ttf", Size=38.099999999999994, Tracking=0.0)
plm=FreeCAD.Placement()
plm.Base=FreeCAD.Vector(0.0, 0.0, 0.0)
plm.Rotation.Q=(0.0, 0.0, 0.0, 1.0)
ss.Placement=plm
ss.Support=None
Draft.autogroup(ss)
App.activeDocument().recompute(None,True,True)
FreeCAD.getDocument('Unnamed').getObject('ShapeString').Placement = App.Placement(App.Vector(127.0000,50.8000,0.0000),App.Rotation(App.Vector(0.0000,0.0000,1.0000),90.0000))
#End of Create Text
#Make 2D wire from the ShapeString
sv0 = Draft.make_shape2dview(FreeCAD.ActiveDocument.ShapeString, FreeCAD.Vector(-0.0, -0.0, 1.0))
#now create the path
import PathCommands
FreeCAD.activeDocument().addObject('Path::FeatureShape','PathShape')
FreeCAD.activeDocument().PathShape.Sources = [ FreeCAD.activeDocument().Shape2DView, ]
#inspect the Path Gcode just created
import PathScripts.PathInspect
PathScripts.PathInspect.show(FreeCAD.ActiveDocument.PathShape)
To get the GCode in inches I suggest First you create a Job and then run the below code in the Python Console to add your PathShape to the job. You will now be able to post your code out like any other Path created in the job. See the video for visual help https://youtu.be/OwOfs_p5wKk
import PathScripts.PathUtils
PathScripts.PathUtils.addToJob(App.ActiveDocument.PathShape)
