memfis wrote: ↑Wed May 04, 2022 9:40 am
Please clarify - "who stands on whom"? in the sense that creating your tool library should -
1. one file of shape description fcstd in the Shape directory should be created for each type of tool (many tools of different size of the same type)
One original .FCStd required.
The one .FCStd file does all sizes of the same tool by changing the attributes values in the dialog when a new tool is created.
+ one file fctb with individual dimensions for each instance
Only one original is required. This one file is the pattern from which new tools are created.
The one .fctb file has an initial size, more tools are created based on this. It provides the Attributes reference for the creation of a new .fctb file for the tool you are constructing .
For example a standard 3mm endmill.fctb is supplied in the installed tools. When a new toolbit is created a it is saved with a new name and the attributes edited (in the dialog) for the new toolbit. The result is a new unique toolbit, and the original still exists.
2. each instance of a tool has its own pair of fcstd + fctb?
In the sense of correct use, including for simulation?
Only the original pair for each toolbit type, all other instances are built from them in the creation dialog.
Is there a library somewhere with sets of such templates (file pairs)? - so that there will be no conflicts of names and mutual understanding between the creator of the tool form and the program code when you try to create it yourself.
To create a new type of toolbit, I open an existing .fctb file (from the Bit directory) and edit it and "Save As" a new definition for a new tool.
Sliptonic did a recent video at
https://www.youtube.com/watch?v=fgCPmCEnndo
A good step by step hard copy guide procedure here
https://forum.freecadweb.org/viewtopic. ... 65#p577865
