Ok I got it to work, still has same bug as the original which is that some comments slip true the filter.
But it now has double removes.It does has my own custom M6 command, but I left it in for anyone who want an example on how you implement a M6 on a Marlin machine.
Edit: Tested it and it worked! Although I did not use the drill function.
# * Copyright (c) 2014 sliptonic <shopinthewoods@gmail.com> *
# * This file is part of the FreeCAD CAx development system. *
# * This program is free software; you can redistribute it and/or modify *
# * it under the terms of the GNU Lesser General Public License (LGPL) *
# * as published by the Free Software Foundation; either version 2 of *
# * the License, or (at your option) any later version. *
# * for detail see the LICENCE text file. *
# * FreeCAD is distributed in the hope that it will be useful, *
# * but WITHOUT ANY WARRANTY; without even the implied warranty of *
# * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
# * GNU Lesser General Public License for more details. *
# * You should have received a copy of the GNU Library General Public *
# * License along with FreeCAD; if not, write to the Free Software *
# * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 *
# * USA *
from __future__ import print_function
import FreeCAD
from FreeCAD import Units
import Path
import argparse
import datetime
import shlex
from PathScripts import PostUtils
TOOLTIP = """
This is a postprocessor file for the Path workbench. It is used to
take a pseudo-gcode fragment outputted by a Path object, and output
real GCode suitable for a linuxcnc 3 axis mill. This postprocessor, once placed
in the appropriate PathScripts folder, can be used directly from inside
FreeCAD, via the GUI importer or via python scripts with:
import linuxcnc_post
linuxcnc_post.export(object,"/path/to/file.ncc","")
now = datetime.datetime.now()
parser = argparse.ArgumentParser(prog="linuxcnc", add_help=False)
parser.add_argument("--no-header", action="store_true", help="suppress header output")
"--no-comments", action="store_true", help="suppress comment output"
"--line-numbers", action="store_true", help="prefix with line numbers"
"--no-show-editor",
help="don't pop up editor before writing output",
"--precision", default="3", help="number of digits of precision, default=3"
"--translate_drill",
help="translate drill cycles G81, G82, G83 into G0/G1 movements (default)",
"--no-translate_drill",
help="do not translate drill cycles G81, G82, G83 into G0/G1 movements",
"--preamble",
help='set commands to be issued before the first command, default="G17\nG90"',
"--postamble",
help='set commands to be issued after the last command, default="M05\nG17 G90\nM2"',
"--inches", action="store_true", help="Convert output for US imperial mode (G20)"
"--modal",
help="Output the Same G-command Name USE NonModal Mode",
"--axis-modal", action="store_true", help="Output the Same Axis Value Mode"
TOOLTIP_ARGS = parser.format_help()
# These globals set common customization preferences
OUTPUT_COMMENTS = True
OUTPUT_HEADER = True
OUTPUT_LINE_NUMBERS = False
SHOW_EDITOR = True
MODAL = False # if true commands are suppressed if the same as previous line.
OUTPUT_DOUBLES = (
False # if false duplicate axis values are suppressed if the same as previous line.
COMMAND_SPACE = " "
LINENR = 100 # line number starting value
SUPPRESS_COMMANDS = [""] # These commands are ignored by commenting them out
MOTION_MODE = "G55" # G90 only, for absolute moves
MOTION_COMMANDS = ["G0", "G00", "G1", "G01", "G2", "G02", "G3", "G03"]
RAPID_MOVES = ["G0", "G00"] # Rapid moves gcode commands definition
DRILL_RETRACT_MODE = "G98" # End of drill-cycle retractation type. G99
# is the alternative.
TRANSLATE_DRILL_CYCLES = True # If true, G81, G82, and G83 are translated
# into G0/G1 moves
# These globals will be reflected in the Machine configuration of the project
UNITS = "G21" # G21 for metric, G20 for us standard
UNIT_SPEED_FORMAT = "mm/min"
UNIT_FORMAT = "mm"
MACHINE_NAME = "MarlinCNC"
CORNER_MIN = {"x": 0, "y": 0, "z": 0}
CORNER_MAX = {"x": 800, "y": 1270, "z": 50}
PRECISION = 3
# Preamble text will appear at the beginning of the GCODE output file.
PREAMBLE = """
G90
G17
# Postamble text will appear following the last operation.
POSTAMBLE = """
M400
G S4
M42 M1 P19 S1
M42 M1 P20 S1
G0 X0 Y0
M400
# Pre operation text will be inserted before every operation
PRE_OPERATION = """"""
# Post operation text will be inserted after every operation
POST_OPERATION = """"""
# Tool Change commands will be inserted before a tool change
TOOL_CHANGE = """"""
# Global variables storing current position (Use None for safety.)
CURRENT_X = None
CURRENT_Y = None
CURRENT_Z = None
# to distinguish python built-in open function from the one declared below
if open.__module__ in ["__builtin__", "io"]:
pythonopen = open
def processArguments(argstring):
global OUTPUT_HEADER
global OUTPUT_COMMENTS
global OUTPUT_LINE_NUMBERS
global SHOW_EDITOR
global PRECISION
global PREAMBLE
global POSTAMBLE
global UNITS
global UNIT_SPEED_FORMAT
global UNIT_FORMAT
global TRANSLATE_DRILL_CYCLES
global MODAL
global OUTPUT_DOUBLES
try:
args = parser.parse_args(shlex.split(argstring))
if args.no_header:
OUTPUT_HEADER = False
if args.no_comments:
OUTPUT_COMMENTS = False
if args.line_numbers:
OUTPUT_LINE_NUMBERS = True
if args.no_show_editor:
SHOW_EDITOR = False
print("Show editor = %d" % SHOW_EDITOR)
PRECISION = args.precision
if args.preamble is not None:
PREAMBLE = args.preamble
if args.postamble is not None:
POSTAMBLE = args.postamble
if args.no_translate_drill:
TRANSLATE_DRILL_CYCLES = False
if args.translate_drill:
if args.inches:
UNITS = "G20"
UNIT_SPEED_FORMAT = "in/min"
UNIT_FORMAT = "in"
PRECISION = 4
if args.modal:
MODAL = True
if args.axis_modal:
print("here")
OUTPUT_DOUBLES = False
except Exception:
return False
return True
def export(objectslist, filename, argstring):
if not processArguments(argstring):
return None
global UNITS
global UNIT_FORMAT
global SUPPRESS_COMMANDS
for obj in objectslist:
if not hasattr(obj, "Path"):
print(
"the object "
+ obj.Name
+ " is not a path. Please select only path and Compounds."
return None
print("postprocessing...")
gcode = ""
# write header
if OUTPUT_HEADER:
gcode += linenumber() + "(Exported by FreeCAD)\n"
gcode += linenumber() + "(Post Processor: " + __name__ + ")\n"
gcode += linenumber() + "(Output Time:" + str(now) + ")\n"
# Suppress drill-cycle commands:
if TRANSLATE_DRILL_CYCLES:
SUPPRESS_COMMANDS += ["G80", "G98", "G99"]
# Write the preamble
if OUTPUT_COMMENTS:
gcode += linenumber() + "M117(begin preamble)\n"
for line in PREAMBLE.splitlines(False):
gcode += linenumber() + line + "\n"
gcode += linenumber() + UNITS + "\n"
# Skip inactive operations
if hasattr(obj, "Active"):
if not obj.Active:
continue
if hasattr(obj, "Base") and hasattr(obj.Base, "Active"):
if not obj.Base.Active:
continue
# do the pre_op
if OUTPUT_COMMENTS:
gcode += linenumber() + "M117 (begin operation: %s)\n" % obj.Label
gcode += linenumber() + "; (machine units: %s)\n" % (UNIT_SPEED_FORMAT)
for line in PRE_OPERATION.splitlines(True):
# get coolant mode
coolantMode = "None"
if (
hasattr(obj, "CoolantMode")
or hasattr(obj, "Base")
and hasattr(obj.Base, "CoolantMode")
if hasattr(obj, "CoolantMode"):
coolantMode = obj.CoolantMode
else:
coolantMode = obj.Base.CoolantMode
# turn coolant on if required
if OUTPUT_COMMENTS:
if not coolantMode == "None":
gcode += linenumber() + "M117(Coolant On:" + coolantMode + ")\n"
if coolantMode == "Flood":
gcode += linenumber() + "M8" + "\n"
if coolantMode == "Mist":
gcode += linenumber() + "M7" + "\n"
# process the operation gcode
gcode += parse(obj)
# do the post_op
if OUTPUT_COMMENTS:
gcode += linenumber() + "M117(finish operation: %s)\n" % obj.Label
for line in POST_OPERATION.splitlines(True):
# turn coolant off if required
if OUTPUT_COMMENTS:
gcode += linenumber() + "M117(Coolant Off:" + coolantMode + ")\n"
gcode += linenumber() + "M9" + "\n"
# do the post_amble
if OUTPUT_COMMENTS:
gcode += "M117(begin postamble)\n"
for line in POSTAMBLE.splitlines(True):
if FreeCAD.GuiUp and SHOW_EDITOR:
final = gcode
if len(gcode) > 1000000:
print("Skipping editor since output is greater than 100kb")
else:
dia = PostUtils.GCodeEditorDialog()
dia.editor.setText(gcode)
result = dia.exec_()
if result:
final = dia.editor.toPlainText()
else:
final = gcode
print("done postprocessing.")
if not filename == "-":
gfile = pythonopen(filename, "w")
gfile.write(final)
gfile.close()
return final
def linenumber():
global LINENR
if OUTPUT_LINE_NUMBERS is True:
LINENR += 10
return "N" + str(LINENR) + " "
return ""
def format_outstring(strTable):
# construct the line for the final output
global COMMAND_SPACE
s = ""
for w in strTable:
s += w + COMMAND_SPACE
return s.strip()
def parse(pathobj):
global DRILL_RETRACT_MODE
global PRECISION
global MODAL
global UNIT_FORMAT
global MOTION_MODE
global CURRENT_X
global CURRENT_Y
global CURRENT_Z
out = ""
lastcommand = None
precision_string = "." + str(PRECISION) + "f"
currLocation = {} # keep track for no doubles
# the order of parameters
# linuxcnc doesn't want K properties on XY plane Arcs need work.
params = [
"X",
"Y",
"Z",
"A",
"B",
"C",
"U",
"V",
"W",
"I",
"J",
"K",
"F",
"S",
"T",
"Q",
"R",
"L",
"P",
"H",
"D",
firstmove = Path.Command("G0", {"X": -1, "Y": -1, "Z": -1, "F": 0.0})
currLocation.update(firstmove.Parameters) # set First location Parameters
if hasattr(pathobj, "Group"): # We have a compound or project.
if OUTPUT_COMMENTS:
out += linenumber() + "(compound: " + pathobj.Label + ")\n"
for p in pathobj.Group:
out += parse(p)
return out
else: # parsing simple path
# groups might contain non-path things like stock.
if not hasattr(pathobj, "Path"):
return out
if OUTPUT_COMMENTS:
out += linenumber() + ";Path(" + pathobj.Label + ")\n"
for c in pathobj.Path.Commands:
outstring = []
command = c.Name
outstring.append(command)
# if modal: suppress the command if it is the same as the last one
if MODAL is True:
if command == lastcommand:
outstring.pop(0)
if c.Name[0] == "(" and not OUTPUT_COMMENTS: # command is a comment
continue
# Now add the remaining parameters in order
for param in params:
if param in c.Parameters:
if param == "F" and (
currLocation[param] != c.Parameters[param] or OUTPUT_DOUBLES
if c.Name not in RAPID_MOVES: # linuxcnc doesn't use rapid speeds
speed = Units.Quantity(
c.Parameters["F"], FreeCAD.Units.Velocity
if speed.getValueAs(UNIT_SPEED_FORMAT) > 0.0:
outstring.append(
param
+ format(
float(speed.getValueAs(UNIT_SPEED_FORMAT)),
precision_string,
else:
continue
elif param == "T":
outstring.append(param + str(int(c.Parameters["T"])))
elif param == "H":
outstring.append(param + str(int(c.Parameters["H"])))
elif param == "D":
outstring.append(param + str(int(c.Parameters["D"])))
elif param == "S":
outstring.append(param + str(int(c.Parameters["S"])))
elif param == "P":
outstring.append(param + str(int(c.Parameters["P"])))
elif param == "Q":
outstring.append(param + str(int(c.Parameters["Q"])))
elif param == "R":
outstring.append(param + str(int(c.Parameters["R"])))
else:
if (
(not OUTPUT_DOUBLES)
and (param in currLocation)
and (currLocation[param] == c.Parameters[param])
continue
else:
pos = Units.Quantity(
c.Parameters[param], FreeCAD.Units.Length
outstring.append(
param
+ format(
float(pos.getValueAs(UNIT_FORMAT)), precision_string
# store the latest command
lastcommand = command
currLocation.update(c.Parameters)
if command in MOTION_COMMANDS:
if "X" in c.Parameters:
CURRENT_X = Units.Quantity(c.Parameters["X"], FreeCAD.Units.Length)
if "Y" in c.Parameters:
CURRENT_Y = Units.Quantity(c.Parameters["Y"], FreeCAD.Units.Length)
if "Z" in c.Parameters:
CURRENT_Z = Units.Quantity(c.Parameters["Z"], FreeCAD.Units.Length)
if command in ("G98", "G99"):
DRILL_RETRACT_MODE = command
if command in ("G81", "G82", "G83"):
out += drill_translate(outstring, command, c.Parameters)
#Erase the line just translated:
outstring = []
# Check for Tool Change:
if command in ("M6", "M06"):
out += "M400 ; wait till everything ended"
out += "\n"
out += "M42 M1 P19 S1 ;spindle off"
out += "\n"
out += "M42 M1 P20 S1 ; vacuum off"
out += "\n"
out += "G53 ;switch to main coordinate system"
out += "\n"
out += "G0 Z0 ;Z0 has to be the heighest the cnc can go."
out += "\n"
out += "G28 Y ;Home Y first"
out += "\n"
out += "G28 X ;Home X next"
out += "\n"
out += "G55 ;change to workspace 2"
out += "\n"
out += "G0 Z0 ;Go to 0 of workspace."
out += "\n"
out += "M0 Install tool: {}; change bit".format(c.Parameters['T'])
out += "\n"
out += "\n"
out += "\n"
out += "\n"
out += "G0 Y0 ; Go Y 0 first"
out += "\n"
out += "G0 X0 ; Go X 0 next"
out += "\n"
out += "M42 M1 P19 S0 ;spindle on"
out += "\n"
out += "M42 M1 P20 S0 ; vacuum on"
out += "\n"
out += "M117 end tool switch"
out += "\n"
outstring = []
if command in ("M3", "M03", "M4", "M04"):
out += "\n"
out += ";(activate Spindle normally M3)"
out += "\n"
out += "M400"
out += "\n"
out += "M42 M1 P19 S0"
out += "\n"
out += "M42 M1 P20 S0"
out += "\n"
out += "G4 S5 ;wait for spindle "
out += "\n"
outstring = []
if command == "message":
if OUTPUT_COMMENTS is False:
out = []
else:
outstring.pop(0) # remove the command
if command in SUPPRESS_COMMANDS:
outstring[0] = ";suppcommands(" + outstring[0]
outstring[-1] = outstring[-1] + ")"
# prepend a line number and append a newline
if len(outstring) >= 1:
if OUTPUT_LINE_NUMBERS:
outstring.insert(0, (linenumber()))
# append the line to the final output
for w in outstring:
out += w + COMMAND_SPACE
# Note: Do *not* strip `out`, since that forces the allocation
# of a contiguous string & thus quadratic complexity.
out += "\n"
return out
# * As of Marlin 2.0.7.bugfix, canned drill cycles do not exist. *
# * The following code converts FreeCAD's canned drill cycles into *
# * gcode that Marlin can use. *
def drill_translate(outstring, cmd, params):
global MOTION_MODE
global CURRENT_X
global CURRENT_Y
global CURRENT_Z
global UNITS
global UNIT_FORMAT
global PRECISION
class Drill: # Using a class is necessary for the nested functions.
gcode = ""
strFormat = "." + str(PRECISION) + "f"
if OUTPUT_COMMENTS: # Comment the original command
outstring[0] = ";(" + outstring[0]
Drill.gcode += linenumber() + format_outstring(outstring) + "\n"
# Cycle conversion only converts the cycles in the XY plane (G17).
# --> ZX (G18) and YZ (G19) planes produce false gcode.
drill_X = Units.Quantity(params["X"], FreeCAD.Units.Length)
drill_Y = Units.Quantity(params["Y"], FreeCAD.Units.Length)
drill_Z = Units.Quantity(params["Z"], FreeCAD.Units.Length)
drill_R = Units.Quantity(params["R"], FreeCAD.Units.Length)
drill_F = Units.Quantity(params["F"], FreeCAD.Units.Velocity)
if cmd == "G82":
drill_DwellTime = params["P"]
elif cmd == "G83":
drill_Step = Units.Quantity(params["Q"], FreeCAD.Units.Length)
# R less than Z is error
if drill_R < drill_Z:
Drill.gcode += linenumber() + ";(drill cycle error: R less than Z )\n"
return Drill.gcode
# Z height to retract to when drill cycle is done:
if DRILL_RETRACT_MODE == "G98" and CURRENT_Z > drill_R:
RETRACT_Z = CURRENT_Z
else:
RETRACT_Z = drill_R
# Z motion nested functions:
def rapid_Z_to(new_Z):
Drill.gcode += linenumber() + "G0 Z"
Drill.gcode += format(float(new_Z.getValueAs(UNIT_FORMAT)), strFormat) + "\n"
def feed_Z_to(new_Z):
Drill.gcode += linenumber() + "G1 Z"
Drill.gcode += format(float(new_Z.getValueAs(UNIT_FORMAT)), strFormat) + " F"
Drill.gcode += format(float(drill_F.getValueAs(UNIT_SPEED_FORMAT)), ".2f") + "\n"
# Make sure that Z is not below RETRACT_Z:
if CURRENT_Z < RETRACT_Z:
rapid_Z_to(RETRACT_Z)
# Rapid to hole position XY:
Drill.gcode += linenumber() + "G0 X"
Drill.gcode += format(float(drill_X.getValueAs(UNIT_FORMAT)), strFormat) + " Y"
Drill.gcode += format(float(drill_Y.getValueAs(UNIT_FORMAT)), strFormat) + "\n"
# Rapid to R:
rapid_Z_to(drill_R)
# * Drill cycles: *
# * G80 Cancel the drill cycle *
# * G81 Drill full depth in one pass *
# * G82 Drill full depth in one pass, and pause at the bottom *
# * G83 Drill in pecks, raising the drill to R height after each peck *
# * In preparation for a rapid to the next hole position: *
# * G98 After the hole has been drilled, retract to the initial Z value *
# * G99 After the hole has been drilled, retract to R height *
# * Select G99 only if safe to move from hole to hole at the R height *
if cmd in ("G81", "G82"):
feed_Z_to(drill_Z) # Drill hole in one step
if cmd == "G82": # Dwell time delay at the bottom of the hole
Drill.gcode += linenumber() + "G4 S" + str(drill_DwellTime) + "\n"
# Marlin uses P for milliseconds, S for seconds, change P to S
elif cmd == "G83": # Peck drill cycle:
chip_Space = drill_Step * 0.5
next_Stop_Z = drill_R - drill_Step
while next_Stop_Z >= drill_Z:
feed_Z_to(next_Stop_Z) # Drill one peck of depth
# Set next depth, next_Stop_Z is still at the current hole depth
if (next_Stop_Z - drill_Step) >= drill_Z:
# Rapid up to clear chips:
rapid_Z_to(drill_R)
# Rapid down to just above last peck depth:
rapid_Z_to(next_Stop_Z + chip_Space)
# Update next_Stop_Z to next depth:
next_Stop_Z -= drill_Step
elif next_Stop_Z == drill_Z:
break # Done
else: # More to drill, but less than drill_Step
rapid_Z_to(drill_R)
# Dril remainder of the hole depth:
feed_Z_to(drill_Z)
break # Done
rapid_Z_to(RETRACT_Z) # Done, retract the drill
return Drill.gcode
# print(__name__ + " gcode postprocessor loaded.")
