[Merged] Ticket #6367 - Drilling not generating proper toolpaths
recently there seemed to be quite some development activity related to the path workbench. As there's always some potenzial to make things better, that's great. However, I noticed drilling stopped working, at least for me. The generated toolpaths consist of going to OpStartDepth with a feed move at a single point, rapid moves to the drilling locations at OpStartDepth, drilling the hole and then always travelling back to that single point before the next hole. As a result, they are really unuseable.
Is it only me facing that problem?
OS: Linux 5.4.44-rt27 (KDE//usr/share/xsessions/plasma)
Version: 0.20.26633 (Git)
Hash: da0ac62ccaf55e09cd077489070fb6e2c86333a1
Python version: 3.9.9
Qt version: 5.15.2
OCC version: 7.6.0
Edit: GH ticket [issue]#6367[/issue]
Qt version: 5.15.2
OCC version: 7.6.0
- drilling.FCStd
- (23.28 KiB) Downloaded 39 times
- drilling.png (7.6 KiB) Viewed 1937 times
Reason: added [MERGED] to topic title
Re: Drilling not generating proper toolpaths
I can confirm this. Drilling is not working anymore.
I'm seeing the same thing here.
OS: Linux Mint 20.3 (X-Cinnamon/cinnamon)
Version: 0.20.
Branch: unknown
Hash: 2b8336157bf8eb134c31f00bf20680dad1722cd7
Python version: 3.8.10
Qt version: 5.12.8
OCC version: 7.5.2
Version: 0.20.
Branch: unknown
Qt version: 5.12.8
OCC version: 7.5.2
In my opinion this is introduced by git commit 5b23af3d4b229544ef3b84db28c57aba57fc0bb2
In
variable hole is used also it should be already outdated as it is out of focus?
In
def circularHoleExecute(self, obj, holes):
for hole in holes:
+ v1 = FreeCAD.Vector(hole["x"], hole["y"], obj.StartDepth.Value)
+ v2 = FreeCAD.Vector(hole["x"], hole["y"], obj.FinalDepth.Value - endoffset)
+ edgelist.append(Part.makeLine(v1, v2))
+ # iterate the edgelist and generate gcode
+ for edge in edgelist:
+ PathLog.debug(edge)
# move to hole location
- self.commandlist.append(Path.Command('G0', {'X': p['x'], 'Y': p['y'], 'F': self.horizRapid}))
- self.commandlist.append(Path.Command('G0', {'Z': startHeight, 'F': self.vertRapid}))
- self.commandlist.append(Path.Command('G1', {'Z': obj.StartDepth.Value, 'F': self.vertFeed}))
- # Update changes to parameters
- params.update(cmdParams)
+ command = Path.Command(
+ "G0", {"X": hole["x"], "Y": hole["y"], "F": self.horizRapid}
Re: Ticket #6367 - Drilling not generating proper toolpaths
Added ticket number to thread title
- sliptonic
Thanks for the ticket. I will investigate.
Looking at this, I see an issue related to the depth. Don't rely on the visual representation of the Path, however. For drilling, you really need to scrutinize the gcode because the individual holes are drilled in a canned cycle. The visualization doesn't get canned cycles very well so it's painting a move back to the original hole that doesn't exist.
The goal with this development is two-fold:
First, each target (hole) is handled independently. It's gcode is generated by a drilling 'generator'. This is the first step in removing the assumption built deep into the drill operation that all holes have the same start and end-depth. When done, we should be able to handle holes at different starting and ending planes within a single operation.
Second, we're removing the assumptions about orientation. This is a longer-term goal but is aimed at making it possible to handle drilling targets an a 3+2 rotary so we rotate the part to orient it for drilling.
Both drilling and helix share a lot so please pay attention to both operations over the next few weeks/months. I'm apologizing in advance for any breakage but remember this is a development branch!
mkment wrote: ↑Sat Feb 12, 2022 11:53 am The generated toolpaths consist of going to OpStartDepth with a feed move at a single point, rapid moves to the drilling locations at OpStartDepth, drilling the hole and then always travelling back to that single point before the next hole. As a result, they are really unuseable.
Hi sliptonic,
thanks for the fix. I compiled it and it is working as expected so far.
- sliptonic
Great. Thanks for replying back. The PR is merged
Re: [Merged] Ticket #6367 - Drilling not generating proper toolpaths
Just to let you know the drilling operation isn't working the G81,g73 or G83 seems to be missing, I dont think I did anything wrong have been using the drilling op regularly for some time, also didn't pick up the posible holes from the drawing i had to add them manually..
Regards
John
Regards
John
(Drilling001)
(Begin Drilling)
G0 Z5.000
G90
G99
G0 X3.971 Y20.971
G0 Z3.000
G0 X12.971 Y20.971
G0 Z3.000
G0 X20.971 Y11.471
G0 Z3.000
G0 X20.971 Y3.971
G0 Z3.000
G0 X28.971 Y20.971
G0 Z3.000
G0 X37.971 Y20.971
G0 Z3.000
G0 X20.971 Y30.471
G0 Z3.000
G0 X20.971 Y37.971
G0 Z3.000
G80
G0 Z3.000
G0 Z5.000
(finish operation: Drilling001)
(begin operation: Profile002)
(machine units: mm/min)
OS: Windows 10 (10.0)
Version: 0.21.29485 (Git)
Hash: a236ca843fdd6674afb6d7ed1454fbd3b547f5ea
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
* FeedsAndSpeeds-master 0.4.0
OS: Windows 10 Version 2009
Version: 0.21.30058 (Git)
Hash: cb96332a64db8ae855ca700212eebb0f5151230a
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
Installed mods:
