RampEntryDressup returning to offset zero
Samu
Post by Samu »
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19. Daily
Branch: unknown
Hash: e8566f22bbeb0b7204e3c45519d0963e8881100b
Python version: 3.8.5
Qt version: 5.12.8
OCC version: 7.5.1
The RampEntryDressup always returns to the current offset's X0.0 and Y0.0 coordinates and the clearance height in a straight rapid move before starting the actual milling operation:
(Finish operation: TC: 10mm Slot Cutter)
(Begin operation: RampEntryDressup)
(Coolant On:Flood)
M8
(Path: RampEntryDressup)
G0 X0.000 Y0.000 Z70.000
G0 X300.100 Y37.100 Z70.000
Is there a possibility to turn this off (or comment out the 'responsible' code in the PathDressupRampEntry.py)?
If this line serves a particular purpose and can not be avoided, I would suggest to retract the Z axis first, before returning to the offset zero coordinates (much like a G28 G91 X0 Y0 Z70.0 in Fanuc).
Anschlag_vertikal.FCStd
(43.76 KiB) Downloaded 26 times
Re: RampEntryDressup returning to offset zero
I'm not familiar with other machines, but my very old machine does it all by itself, so I thought it might be a de facto standard: If a rapid move goes up, then it moves Z first, and then X and Y. If a rapid move goes down, then it moves XY first and then Z.
This seems a reasonable strategy to avoid collisions.
Samu
Post by Samu »
chrisb wrote: Wed Mar 31, 2021 8:27 pm I'm not familiar with other machines, but my very old machine does it all by itself, so I thought it might be a de facto standard: If a rapid move goes up, then it moves Z first, and then X and Y. If arapid move goes down, then it moves XY first and then Z.
You're right, it would seem reasonable to have this strategy as a standard. But sadly my mill control and machine do obey this order exactly as written :(
I think it would make sense to not output this line at the beginning of the RampEntryDressup alltogether. Apart from wasting time and potentially causing a crash, I can not see the purpose behind it.
Agreed.
GeneFC
Post by GeneFC »
There were several operations for which this behavior was corrected a few months ago. Sounds like there may be more operations that need correcting.
Gene
jbraun
Post by jbraun »
chrisb wrote: Wed Mar 31, 2021 8:27 pm If a rapid move goes up, then it moves Z first, and then X and Y. If a rapid move goes down, then it moves XY first and then Z.
Yes. I tried to suggest this some time ago but it wasn't well received. It could have been poorly worded on my part as I'm not a great communicator.
For English help on youtube check out Joko Engineering or Mango Jelly Solutions.
Look for recent videos, this software is updated at a rapid pace.
Gimbal
Post by Gimbal »
Sorry for waking up an old thread, but I too have this problem with the RampEntryDressup always starting with G0 X0.000 Y0.000 Z something.
I have a lot of small pockets with rampentrydressup which means a lot of feeding back and forth to x0,y0 for no obvious reason. I can of course edit it out manually, which I will do, but it would be nice if one didn't had to.
