Lead in out dressup for inside profile
flopsy
Re: Lead in out dressup for inside profile
Post by flopsy »
This post is a bit similar withe the problem. To select the start point number for the entry maybe is a solution,too
https://forum.freecadweb.org/viewtopic.php?f=15&t=43896
Gimbal
Post by Gimbal »
Sorry for waking up an old post but I just cant get "lead in" dressup to work with an inside path. The negative length/radius trick does not work as I can't enter a negative value.
If I edit the value in the property field I get the following error: "PathDressupLeadInOut.ERROR: Length/Radius positive not Null" and the negative value I entered is changed to positive 0,10mm.
Am I doing something wrong or is something broken?
OS: Windows 10 (10.0) (Actually it's 11)
Version: 0.20.28717 (Git)
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: Swedish/Sweden (sv_SE)
Installed mods:
* kicadStepUpMod 10.9.2
Gimbal wrote: Sat May 07, 2022 7:10 pm Am I doing something wrong or is something broken?
Upload a file so that the helpers have something to play with.
jescombe
Post by jescombe »
What works for me is setting a start point for the inside profile, so it's not starting in a corner. Then the dressup works as you'd hope..
Inside profile leadin.png (10.75 KiB) Viewed 632 times
Gimbal
Post by Gimbal »
Thanks, I guess one has to manually edit the start point in the property fields which might be a problem when cutting multiple pockets, but it is way forward.
Now for some reason I get a voxel error when simulating the path, but that is another problem. :?
