Optischer Schnitt durch Baugruppe, z.B. für Ventilgehäuse
Re: Optischer Schnitt durch Baugruppe, z.B. für Ventilgehäuse
Hi
thank for upgrade the macro make by aleph0 (and not mario i ave just add one feature and Sam correct for the 0.17 FC version)
but i have error see Sezione Dinamica
and with your modification: first test and after same correction Sam FC stop with the same error window
(ps: the original version does not work anymore ??)
mario
mario
Dear Mario,
thank you for your answer. The original macro still works, but without colours.
@Gift changed the macro and it worked if the parts do not touch each other, please look at this picture:
If the parts are touching each other, the colour from the cutting plane is wrong, and the face is melted into one, no single faces with the part colour, please see this picture:
Is it possible to optimize the macro?
Thank you and best regards
Wilfried
hi freecad-heini-1
I think Gift is more competent than me
@Gift
the upgrade is finished ? (for update the wiki page)
mario
@Gift
mario
Thx 4 your trust. No, the upgrade is not finished. I'm going to revise it. But now is the time to drink beer.
1. If I replace MultiFuse by Part::Compound, is the fusion issue solved. => Part_compound.png
3. The very next step is to cut all objects with Part:Cut. The cut face will dye another color(selectable). Is this solution ok? => A_lot_of_PartCuts.png, A_lot_of_PartCuts2.png
I need more time…
kind regards Benjamin
I need more time…
- A_lot_of_PartCuts2.png (7.59 KiB) Viewed 2936 times
- A_lot_of_PartCuts.png (18.5 KiB) Viewed 2936 times
- Anarchy.png (16.73 KiB) Viewed 2936 times
- Part_compound.png (4.48 KiB) Viewed 2936 times
Danke sehr Benjamin.Gift wrote: ↑Mon Sep 04, 2017 7:46 pm 1. If I replace MultiFuse by Part::Compound, is the fusion issue solved. => Part_compound.png
I need more time…
A update to test.
Todo:
* optimize the loop (initialize some objects out of the loop)
* some error messages with outline
* cut object: “Cannot compute Inventor representation for the shape of Compound”. Maybe some very empty shapes?
Todo:
# -*- coding: utf-8 -*-
* This widget makes an interactively moveable cross-section of the *
* currently visible objects in the currently active document. The *
* cross-sectioning plane is specified by its normal, and the cross- *
* section can be moved along that normal using a slider bar. It can *
* show the cross-section either as an outline or a view of the sliced *
* objects. To run the macro, first download it from this site and *
* install it in your macros directory, then use the menu to call up *
* your list of macros and double-click on this one. It will display *
* a default cross-section and pop up a window to enable you to set *
* the cross-sectioning parameters. Closing the pop-up window will *
* restore the scene to its previous state before the macro was *
* started. *
* Copyright (c) 2016 Richard P. Parkins, M. A. *
* This file is a supplement to the FreeCAD CAx development system. *
* This program is free software; you can redistribute it and/or modify *
* it under the terms of the GNU Lesser General Public License (LGPL) *
* as published by the Free Software Foundation; either version 2 of *
* the License, or (at your option) any later version. *
* for detail see the LICENCE text file. *
* This software is distributed in the hope that it will be useful, *
* but WITHOUT ANY WARRANTY; without even the implied warranty of *
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
* GNU Library General Public License for more details. *
* You should have received a copy of the GNU Library General Public *
* License along with this macro; if not, write to the Free Software *
* Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 *
* USA *
__title__ = "Cross-Section"
__author__ = "Aleph0"
__version__ = "00.04"
__date__ = "29/01/2016" "10/06/2016" "29/09/2016 * 2"
__Comment__ = "Dynamic cross section viewer"
__Wiki__ = "http://www.freecadweb.org/wiki/index.php?title=Macro_cross_section"
__Help__ = "see first few lines of macro text"
__Status__ = "stable"
__Requires__ = "freecad 0.15"
# OS: Ubuntu 14.04.3 LTS
# Word size of OS: 64-bit
# Word size of FreeCAD: 64-bit
# Version: 0.15.4671 (Git)
# Branch: releases/FreeCAD-0-15
# Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
# Python version: 2.7.6
# Qt version: 4.8.6
# Coin version: 4.0.0a
# OCC version: 6.8.0.oce-0.17
import PySide
import FreeCADGui
from FreeCAD import Base
try:
_fromUtf8 = QtCore.QString.fromUtf8
except AttributeError:
def _fromUtf8(s):
return s
try:
_encoding = QtGui.QApplication.UnicodeUTF8
def _translate(context, text, disambig):
return QtGui.QApplication.translate(context, text, disambig, _encoding)
return QtGui.QApplication.translate(context, text, disambig)
width = 350 # width of our window
height = 310 # height of our window
global FreeCADRootWindow # main window before we start
# This is the interactive window that the macro creates
# Its main function is to have a close box and tidy up when closed
class CrossSectionWindow(PySide.QtGui.QMainWindow):
# automagically called when the window is created
def __init__(self):
super(CrossSectionWindow, self).__init__()
self.setWindowFlags(PySide.QtCore.Qt.WindowStaysOnTopHint)
self.setWindowTitle(_translate(
"MainWindow", "Cross-section", None))
# Create and set the window's widget, which does all the work
self.child = CrossSection(self)
self.setCentralWidget(self.child)
self.child.initUI(self)
if self.child.startup_failed :
self.destroy()
else:
# Position our window relative to the FreeCAD root
self.setPosition(FreeCADRootWindow)
self.child.show()
self.show()
# User closed the window, tidy up
def closeEvent(self, event) :
self.child.restoreObjects()
# Set a sensible default position for the window
# With FreeCAD's default layout, this will be over the docking area
# so it will not obscure the 3D view
def setPosition(self, parent) :
geom = parent.geometry()
xpos = geom.left() + 50
ypos = geom.center().y() - height / 2
self.setGeometry(xpos, ypos, width, height)
self.setFixedSize(width, height)
# This is the widget which does almost all of the work
# Widgets don't have close boxes, so closing is dealt with in CrossSectionWindow
class CrossSection(PySide.QtGui.QWidget):
# Lay out the interactive elements
def initUI(self, parent):
self.parent = parent
font = QtGui.QFont()
font.setFamily("Times New Roman")
font.setPointSize(10)
font.setWeight(10)
font.setBold(True)
self.hideObjects()
margin = 10
alw = 20 # axis label width
sbp = margin + alw + margin # spin boxes to right of axis labels
slw = width - 2 * margin # width of slider and progress bar
ypos = margin
self.setObjectName(_fromUtf8("CrossSection"))
# The cross-section plane is defined by its normal
# The length of the normal is immaterial as long as it is nonzero
self.label_1 = QtGui.QLabel(self)
self.label_1.setGeometry(QtCore.QRect(margin, ypos, slw, 22))
self.label_1.setObjectName(_fromUtf8("label_1"))
self.label_1.setText(_translate(
"MainWindow", "Sliding axis direction", None))
self.label_1.setToolTip(_translate(
"MainWindow",
"Cross-section is taken perpendicular to this axis", None))
ypos = ypos + 30
self.label_2 = QtGui.QLabel(self)
self.label_2.setGeometry(QtCore.QRect(margin, ypos, alw, 25))
self.label_2.setObjectName(_fromUtf8("label_2"))
self.label_2.setText(_translate("MainWindow", "X", None))
self.doubleSpinBox_X = QtGui.QDoubleSpinBox(self)
self.doubleSpinBox_X.setGeometry(QtCore.QRect(sbp, ypos, 62, 25))
self.doubleSpinBox_X.setMinimum(-10000.0)
self.doubleSpinBox_X.setMaximum(10000.0)
self.doubleSpinBox_X.setValue(0.0)
self.doubleSpinBox_X.setSingleStep(1)
self.doubleSpinBox_X.setObjectName(_fromUtf8("doubleSpinBox_X"))
self.doubleSpinBox_X.valueChanged.connect(
self.on_doubleSpinBox_X_valueChanged)
self.doubleSpinBox_X.setToolTip(_translate(
"MainWindow", "Sliding axis X", None))
ypos = ypos + 30
self.label_3 = QtGui.QLabel(self)
self.label_3.setGeometry(QtCore.QRect(margin, ypos, alw, 25))
self.label_3.setObjectName(_fromUtf8("label_3"))
self.label_3.setText(_translate("MainWindow", "Y", None))
self.doubleSpinBox_Y = QtGui.QDoubleSpinBox(self)
self.doubleSpinBox_Y.setGeometry(QtCore.QRect(sbp, ypos, 62, 25))
self.doubleSpinBox_Y.setMinimum(-10000.0)
self.doubleSpinBox_Y.setMaximum(10000.0)
self.doubleSpinBox_Y.setValue(0.0)
self.doubleSpinBox_Y.setSingleStep(1)
self.doubleSpinBox_Y.setObjectName(_fromUtf8("doubleSpinBox_Y"))
self.doubleSpinBox_Y.valueChanged.connect(
self.on_doubleSpinBox_Y_valueChanged)
self.doubleSpinBox_Y.setToolTip(_translate(
"MainWindow", "Sliding axis Y", None))
ypos = ypos + 30
self.label_4 = QtGui.QLabel(self)
self.label_4.setGeometry(QtCore.QRect(margin, ypos, alw, 25))
self.label_4.setObjectName(_fromUtf8("label_4"))
self.label_4.setText(_translate("MainWindow", "Z", None))
self.doubleSpinBox_Z = QtGui.QDoubleSpinBox(self)
self.doubleSpinBox_Z.setGeometry(QtCore.QRect(sbp, ypos, 62, 25))
self.doubleSpinBox_Z.setMinimum(-10000.0)
self.doubleSpinBox_Z.setMaximum(10000.0)
self.doubleSpinBox_Z.setValue(1.0)
self.doubleSpinBox_Z.setSingleStep(1)
self.doubleSpinBox_Z.setObjectName(_fromUtf8("doubleSpinBox_Z"))
self.doubleSpinBox_Z.valueChanged.connect(
self.on_doubleSpinBox_Z_valueChanged)
self.doubleSpinBox_Z.setToolTip(
_translate("MainWindow", "Sliding axis Z", None))
ypos = ypos + 40
# Make the interactive slider control
# As you move this slider with the mouse, the cross-section slides
# through the model
self.label_5 = QtGui.QLabel(self)
self.label_5.setGeometry(QtCore.QRect(margin, ypos, slw, 22))
self.label_5.setObjectName(_fromUtf8("label_5"))
self.label_5.setText(_translate(
"MainWindow", "Position along axis", None))
ypos = ypos + 30
self.horizontalSlider = QtGui.QSlider(self)
self.horizontalSlider.setGeometry(QtCore.QRect(margin, ypos, slw-50, 20))
self.horizontalSlider.setOrientation(QtCore.Qt.Horizontal)
self.horizontalSlider.setInvertedAppearance(False)
self.horizontalSlider.setObjectName(_fromUtf8("horizontalSlider"))
self.horizontalSlider.setRange(0, 100)
self.horizontalSlider.setValue(int(self.fraction * 100.0))
self.horizontalSlider.setToolTip(_translate(
"MainWindow", "Slide to move cross-section along axis", None))
# must be called after setValue()
self.horizontalSlider.valueChanged.connect(self.on_horizontal_slider)
ypos = ypos + 30
self.progressBar_1 = QtGui.QProgressBar(self)
self.progressBar_1.setGeometry(QtCore.QRect(margin, ypos, slw-50, 23))
self.progressBar_1.setValue(int(self.fraction * 100.0))
self.progressBar_1.setOrientation(QtCore.Qt.Horizontal)
self.progressBar_1.setAlignment(QtCore.Qt.AlignCenter)
self.progressBar_1.setObjectName(_fromUtf8("progressBar_1"))
self.progressBar_1.setToolTip(_translate(
"MainWindow", "Percent position of cross-section", None))
ypos = ypos + 40
################################## add
self.SpinBox_PBar = QtGui.QSpinBox(self)
self.SpinBox_PBar.setGeometry(QtCore.QRect(sbp+255, ypos-40, 45, 23))
self.SpinBox_PBar.setMinimum(0.0)
self.SpinBox_PBar.setMaximum(100.0)
self.SpinBox_PBar.setValue(int(self.fraction * 100.0))
self.SpinBox_PBar.setSingleStep(1)
self.SpinBox_PBar.setObjectName(_fromUtf8("SpinBox_PBar"))
self.SpinBox_PBar.valueChanged.connect(self.on_SpinBox_PBar_valueChanged)
self.SpinBox_PBar.setToolTip(_translate(
"MainWindow", "Sliding percent", None))
# Select the display format for the cross-section
# This button shows a wire line in the cross-section plane
self.radioButton_1 = QtGui.QRadioButton(self)
self.radioButton_1.setGeometry(QtCore.QRect(margin, ypos, slw, 20))
self.radioButton_1.setText(_fromUtf8("Outline"))
self.radioButton_1.setChecked(True)
self.radioButton_1.toggled.connect(self.onRadioButton)
self.radioButton_1.setObjectName(_fromUtf8("radioButton_1"))
self.radioButton_1.setToolTip(_translate(
"MainWindow", "Make cross-section as wire outline", None))
ypos = ypos + 30
# This button shows a normal 3D display with everything above the
# cross-section plane cut away
self.radioButton_2 = QtGui.QRadioButton(self)
self.radioButton_2.setGeometry(QtCore.QRect(margin, ypos, slw, 20))
self.radioButton_2.setText(_fromUtf8("Cut objects"))
self.radioButton_2.setChecked(False)
self.radioButton_2.toggled.connect(self.onRadioButton)
self.radioButton_2.setObjectName(_fromUtf8("radioButton_2"))
self.radioButton_2.setToolTip(_translate(
"MainWindow", "Make cross-section as cut objects", None))
#Keep the sectional view
self.CB_00 = QtGui.QCheckBox(self)
self.CB_00.setText(_fromUtf8("Keep the sectional view"))
self.CB_00.setGeometry(QtCore.QRect(margin+168, ypos-30, slw, 20))
self.CB_00.setObjectName(_fromUtf8("CB_00"))
self.CB_00.setChecked(False)
self.CB_00.setToolTip(_translate(
"MainWindow", "Keep the sectional view or erase", None))
# Called at macro start up by initUI()
def hideObjects(self):
# Initialise the cross-section state variables
self.startup_failed = False
self.fraction = 0.5
self.axisX = 0.0
self.axisY = 0.0
self.axisZ = 1.0
self.cross_section_type = 1
# We must have something to do a cross-section on
if App.ActiveDocument is None :
QtGui.QMessageBox.warning(None, _translate("MainWindow",
"Cross-section", None),
_translate("MainWindow", "There is no Active Document\n" +
"Create one and run this macro again.", None),
QtGui.QMessageBox.Cancel,
QtGui.QMessageBox.Cancel)
self.startup_failed = True
self.parent.destroy() # This will close the window
else :
# Make a list of the user's objects
# WARNING!!
# This list is persistent. We'll get confused if the user deletes or
# adds objects while the macro is active
self.oblist = App.ActiveDocument.Objects
# Create the cross-section object
self.cs = FreeCAD.ActiveDocument.addObject("Part::Feature",
"Generated__cross-section")
self.OriginalVisibilities = list()
self.xmin = 1000.0
self.xmax = -1000.0
self.ymin = 1000.0
self.ymax = -1000.0
self.zmin = 1000.0
self.zmax = -1000.0
# n = 0
# for p in self.oblist: # stupid Python list has no length function
# n = n + 1
############################# Skip the <group object> ######################## # add
b0 = []
for x0 in self.oblist:
if str(x0) != "<group object>":
b0.append(x0)
self.oblist = b0
n = len(self.oblist)
# Make a list of the visible objects and make them invisible while
# the macro is active
# Also we compute the bounding box of the model
for i in range(n):
vis = self.oblist[i].ViewObject.Visibility
self.OriginalVisibilities.append(vis)
if vis :
if self.oblist[i].TypeId != str("Drawing::FeatureViewPython") : # add
self.oblist[i].ViewObject.Visibility=False
b = self.oblist[i].Shape.BoundBox
if b.XMin < self.xmin :
self.xmin = b.XMin
if b.XMax > self.xmax :
self.xmax = b.XMax
if b.YMin < self.ymin :
self.ymin = b.YMin
if b.YMax > self.ymax :
self.ymax = b.YMax
if b.ZMin < self.zmin :
self.zmin = b.ZMin
if b.ZMax > self.zmax :
self.zmax = b.ZMax
# Moan and give up if there is nothing to cross-section
if self.xmax <= self.xmin \
or self.ymax <= self.ymin \
or self.zmax <= self.zmin :
"There are no visible solid objects\n" +
"Create some and run this macro again.", None),
self.restoreObjects()
App.ActiveDocument.removeObject("Generated__cross_section")
else :
# Trigger initial display
self.updateAxis()
# Called when macro is closed
# Restore the original visibility of the user's objects
# and destroy our cross-section object
def restoreObjects(self):
n = 0
n = n + 1
for i in range(n):
self.oblist[i].ViewObject.Visibility = self.OriginalVisibilities[i]
try:
if self.CB_00.isChecked() == False:
except Exception:
None
# Something has changed, recalculate the cross-section
def updateGui(self):
# default to no visible cross-ection
self.cs.ViewObject.Visibility = False
# check if the sliding axis is invalid
if self.xdir == 0.0 and self.ydir == 0.0 and self.zdir == 0.0 :
_translate("MainWindow", "The sliding axis has zero length\n" +
"Please set a valid axis.", None),
QtGui.QMessageBox.Ok,
QtGui.QMessageBox.Ok)
else :
# First we compute the 0% and 100% positions on the sliding axis
if self.xdir < 0.0 :
x = self.xmax + self.fraction * self.xdir
else :
x = self.xmin + self.fraction * self.xdir
if self.ydir < 0.0 :
y = self.ymax + self.fraction * self.ydir
else :
y = self.ymin + self.fraction * self.ydir
if self.zdir < 0.0 :
z = self.zmax + self.fraction * self.zdir
else :
z = self.zmin + self.fraction * self.zdir
r = 2 * max(self.xmax - self.xmin, self.ymax - self.ymin,
self.zmax - self.xmin)
# Display the dimensions
dimDep = "X "+str(x)+" mm , Y "+str(y)+" mm , Z "+str(z)+" mm"
App.Console.PrintMessage(dimDep + "\n")
# Create a big enough disc in the cross-section plane
c = Part.makeCircle(r, Base.Vector(x, y, z),
Base.Vector(self.xdir, self.ydir, self.zdir))
f = Part.Face(Part.Wire(c))
l = list() # list for cross-section parts
h = list()
n = 0
n = n + 1
something = False
if self.cross_section_type == 1 :
# wire line cross-section
for i in range(n):
if self.OriginalVisibilities[i] :
ob = FreeCAD.ActiveDocument.addObject("Part::Feature")
ob.ViewObject.DiffuseColor = self.oblist[i].ViewObject.DiffuseColor
ob.Shape = self.oblist[i].Shape.section(f)
# check for valid section part
if ob.Shape.BoundBox.XMin <= ob.Shape.BoundBox.XMax :
l.append(ob)
something = True
else:
FreeCAD.ActiveDocument.removeObject(ob.Name)
else :
# cut shape cross-section
# extrude our cross-ection disc into a cylinder
cyl = f.extrude(Base.Vector(self.xdir, self.ydir, self.zdir))
doc = FreeCAD.ActiveDocument
for i in range(n):
acut = doc.addObject("Part::Cut","Cut")
abase = Draft.clone(self.oblist[i])
atool = doc.addObject("Part::Feature")
atool.Shape = cyl
atool.ViewObject.ShapeColor=(0.25,0.57,0.35)
doc.recompute()
acut.Base = abase
acut.Tool = atool
acut.ViewObject.DiffuseColor = abase.ViewObject.DiffuseColor
doc.recompute()
ob = doc.addObject("Part::Feature")
ob.Shape = acut.Shape
ob.ViewObject.DiffuseColor = acut.ViewObject.DiffuseColor
doc.recompute()
doc.removeObject(acut.Name)
doc.recompute()
doc.removeObject(abase.Name)
doc.recompute()
doc.removeObject(atool.Name)
doc.recompute()
if ob.Shape.isValid() and ob.Shape.Volume > 0.0 :
l.append(ob)
something = True
else:
doc.removeObject(ob.Name)
if something :
feature = FreeCAD.ActiveDocument.addObject("Part::Compound","Compound")
feature.Links = l
FreeCAD.ActiveDocument.recompute()
if feature.Shape.isValid() :
self.cs.Shape = feature.Shape.copy()
self.cs.ViewObject.DiffuseColor = feature.ViewObject.DiffuseColor
self.cs.ViewObject.Visibility = True
for od in l:
FreeCAD.ActiveDocument.removeObject(od.Name)
FreeCAD.ActiveDocument.removeObject(feature.Name)
FreeCADGui.updateGui()
# User changed axis vector
# Compute a new axis vector whose length just covers the model
def updateAxis(self):
ldir = 0.0
if self.axisX != 0.0 :
ldir = (self.xmax - self.xmin) / abs(self.axisX)
if self.axisY != 0.0 :
ldir = max(ldir, (self.ymax - self.ymin) / abs(self.axisY))
if self.axisZ != 0.0 :
ldir = max(ldir, (self.zmax - self.zmin) / abs(self.axisZ))
self.xdir = self.axisX * ldir
self.ydir = self.axisY * ldir
self.zdir = self.axisZ * ldir
self.updateGui() # recalculate the cross-section
def on_horizontal_slider(self, val):
self.fraction = val / 100.0
self.progressBar_1.setValue(val)
self.SpinBox_PBar.setValue(val)
self.updateGui()
def on_doubleSpinBox_X_valueChanged(self, val):
self.axisX = val
self.updateAxis()
def on_doubleSpinBox_Y_valueChanged(self, val):
self.axisY = val
self.updateAxis()
def on_doubleSpinBox_Z_valueChanged(self, val):
self.axisZ = val
self.updateAxis()
def on_SpinBox_PBar_valueChanged(self, val):
self.horizontalSlider.setValue(int(val))
self.updateGui()
def onRadioButton(self, wasChecked) :
if self.radioButton_1.isChecked() :
else :
self.cross_section_type = 2
self.updateGui()
# Find FreeCAD's root window
FreeCADRootWindow = Gui.getMainWindow()
# Create the window and start it
myWidget = CrossSectionWindow()
# The CrossSectionWindow will do all the work
- cross_section_with_color.zip
- (5.84 KiB) Downloaded 115 times
Hi
the beer are beautiful effect
thanks for your work i have upgrade the wiki page
mario
EDIT: 21:42 Paris time
i have error
1: Error Draft i add in the macro import Draft
after
2:
X 0.0 mm , Y 0.0 mm , Z 5.0 mm
File "C:/Users/xxxx/AppData/Roaming/FreeCAD/Macro/Macro_cross_section.FCMacro", line 566, in <module>
File "C:/Users/xxxx/AppData/Roaming/FreeCAD/Macro/Macro_cross_section.FCMacro", line 102, in __init__
File "C:/Users/xxxx/AppData/Roaming/FreeCAD/Macro/Macro_cross_section.FCMacro", line 140, in initUI
self.hideObjects()
File "C:/Users/xxxx/AppData/Roaming/FreeCAD/Macro/Macro_cross_section.FCMacro", line 386, in hideObjects
self.updateAxis()
File "C:/Users/xxxx/AppData/Roaming/FreeCAD/Macro/Macro_cross_section.FCMacro", line 527, in updateAxis
File "C:/Users/xxxx/AppData/Roaming/FreeCAD/Macro/Macro_cross_section.FCMacro", line 458, in updateGui
ob.Shape = self.oblist.Shape.section(f)
<class 'Part.OCCError'>: Base shape is null
Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
with FC017 same FreeCAD stop
mario
mario
i have error
after
2:
self.hideObjects()
self.updateAxis()
mario
Funktioniert bei mir leider nicht. Dennoch vielen Dank für die Mühe.Gift wrote: ↑Wed Sep 06, 2017 3:02 pm A update to test.
Todo:
# -*- coding: utf-8 -*- """ *************************************************************************** * * * This widget makes an interactively moveable cross-section of the * * currently visible objects in the currently active document. The * * cross-sectioning plane is specified by its normal, and the cross- * * section can be moved along that normal using a slider bar. It can * * show the cross-section either as an outline or a view of the sliced * * objects. To run the macro, first download it from this site and * * install it in your macros directory, then use the menu to call up * * your list of macros and double-click on this one. It will display * * a default cross-section and pop up a window to enable you to set * * the cross-sectioning parameters. Closing the pop-up window will * * restore the scene to its previous state before the macro was * * started. * * * *************************************************************************** * Copyright (c) 2016 Richard P. Parkins, M. A. * * * * This file is a supplement to the FreeCAD CAx development system. * * * * This program is free software; you can redistribute it and/or modify * * it under the terms of the GNU Lesser General Public License (LGPL) * * as published by the Free Software Foundation; either version 2 of * * the License, or (at your option) any later version. * * for detail see the LICENCE text file. * * * * This software is distributed in the hope that it will be useful, * * but WITHOUT ANY WARRANTY; without even the implied warranty of * * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * * GNU Library General Public License for more details. * * * * You should have received a copy of the GNU Library General Public * * License along with this macro; if not, write to the Free Software * * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 * * USA * *************************************************************************** """ __title__ = "Cross-Section" __author__ = "Aleph0" __version__ = "00.04" __date__ = "29/01/2016" "10/06/2016" "29/09/2016 * 2" __Comment__ = "Dynamic cross section viewer" __Wiki__ = "http://www.freecadweb.org/wiki/index.php?title=Macro_cross_section" __Help__ = "see first few lines of macro text" __Status__ = "stable" __Requires__ = "freecad 0.15" # OS: Ubuntu 14.04.3 LTS # Word size of OS: 64-bit # Word size of FreeCAD: 64-bit # Version: 0.15.4671 (Git) # Branch: releases/FreeCAD-0-15 # Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c # Python version: 2.7.6 # Qt version: 4.8.6 # Coin version: 4.0.0a # OCC version: 6.8.0.oce-0.17 import PySide from PySide import QtCore, QtGui import FreeCADGui from FreeCAD import Base try: _fromUtf8 = QtCore.QString.fromUtf8 except AttributeError: def _fromUtf8(s): return s try: _encoding = QtGui.QApplication.UnicodeUTF8 def _translate(context, text, disambig): return QtGui.QApplication.translate(context, text, disambig, _encoding) except AttributeError: def _translate(context, text, disambig): return QtGui.QApplication.translate(context, text, disambig) width = 350 # width of our window height = 310 # height of our window global FreeCADRootWindow # main window before we start # This is the interactive window that the macro creates # Its main function is to have a close box and tidy up when closed class CrossSectionWindow(PySide.QtGui.QMainWindow): # automagically called when the window is created def __init__(self): super(CrossSectionWindow, self).__init__() self.setWindowFlags(PySide.QtCore.Qt.WindowStaysOnTopHint) self.setWindowTitle(_translate( "MainWindow", "Cross-section", None)) # Create and set the window's widget, which does all the work self.child = CrossSection(self) self.setCentralWidget(self.child) self.child.initUI(self) if self.child.startup_failed : self.destroy() else: # Position our window relative to the FreeCAD root self.setPosition(FreeCADRootWindow) self.child.show() self.show() # User closed the window, tidy up def closeEvent(self, event) : self.child.restoreObjects() # Set a sensible default position for the window # With FreeCAD's default layout, this will be over the docking area # so it will not obscure the 3D view def setPosition(self, parent) : geom = parent.geometry() xpos = geom.left() + 50 ypos = geom.center().y() - height / 2 self.setGeometry(xpos, ypos, width, height) self.setFixedSize(width, height) # This is the widget which does almost all of the work # Widgets don't have close boxes, so closing is dealt with in CrossSectionWindow class CrossSection(PySide.QtGui.QWidget): # Lay out the interactive elements def initUI(self, parent): self.parent = parent font = QtGui.QFont() font.setFamily("Times New Roman") font.setPointSize(10) font.setWeight(10) font.setBold(True) self.hideObjects() margin = 10 alw = 20 # axis label width sbp = margin + alw + margin # spin boxes to right of axis labels slw = width - 2 * margin # width of slider and progress bar ypos = margin self.setObjectName(_fromUtf8("CrossSection")) # The cross-section plane is defined by its normal # The length of the normal is immaterial as long as it is nonzero self.label_1 = QtGui.QLabel(self) self.label_1.setGeometry(QtCore.QRect(margin, ypos, slw, 22)) self.label_1.setObjectName(_fromUtf8("label_1")) self.label_1.setText(_translate( "MainWindow", "Sliding axis direction", None)) self.label_1.setToolTip(_translate( "MainWindow", "Cross-section is taken perpendicular to this axis", None)) ypos = ypos + 30 self.label_2 = QtGui.QLabel(self) self.label_2.setGeometry(QtCore.QRect(margin, ypos, alw, 25)) self.label_2.setObjectName(_fromUtf8("label_2")) self.label_2.setText(_translate("MainWindow", "X", None)) self.doubleSpinBox_X = QtGui.QDoubleSpinBox(self) self.doubleSpinBox_X.setGeometry(QtCore.QRect(sbp, ypos, 62, 25)) self.doubleSpinBox_X.setMinimum(-10000.0) self.doubleSpinBox_X.setMaximum(10000.0) self.doubleSpinBox_X.setValue(0.0) self.doubleSpinBox_X.setSingleStep(1) self.doubleSpinBox_X.setObjectName(_fromUtf8("doubleSpinBox_X")) self.doubleSpinBox_X.valueChanged.connect( self.on_doubleSpinBox_X_valueChanged) self.doubleSpinBox_X.setToolTip(_translate( "MainWindow", "Sliding axis X", None)) ypos = ypos + 30 self.label_3 = QtGui.QLabel(self) self.label_3.setGeometry(QtCore.QRect(margin, ypos, alw, 25)) self.label_3.setObjectName(_fromUtf8("label_3")) self.label_3.setText(_translate("MainWindow", "Y", None)) self.doubleSpinBox_Y = QtGui.QDoubleSpinBox(self) self.doubleSpinBox_Y.setGeometry(QtCore.QRect(sbp, ypos, 62, 25)) self.doubleSpinBox_Y.setMinimum(-10000.0) self.doubleSpinBox_Y.setMaximum(10000.0) self.doubleSpinBox_Y.setValue(0.0) self.doubleSpinBox_Y.setSingleStep(1) self.doubleSpinBox_Y.setObjectName(_fromUtf8("doubleSpinBox_Y")) self.doubleSpinBox_Y.valueChanged.connect( self.on_doubleSpinBox_Y_valueChanged) self.doubleSpinBox_Y.setToolTip(_translate( "MainWindow", "Sliding axis Y", None)) ypos = ypos + 30 self.label_4 = QtGui.QLabel(self) self.label_4.setGeometry(QtCore.QRect(margin, ypos, alw, 25)) self.label_4.setObjectName(_fromUtf8("label_4")) self.label_4.setText(_translate("MainWindow", "Z", None)) self.doubleSpinBox_Z = QtGui.QDoubleSpinBox(self) self.doubleSpinBox_Z.setGeometry(QtCore.QRect(sbp, ypos, 62, 25)) self.doubleSpinBox_Z.setMinimum(-10000.0) self.doubleSpinBox_Z.setMaximum(10000.0) self.doubleSpinBox_Z.setValue(1.0) self.doubleSpinBox_Z.setSingleStep(1) self.doubleSpinBox_Z.setObjectName(_fromUtf8("doubleSpinBox_Z")) self.doubleSpinBox_Z.valueChanged.connect( self.on_doubleSpinBox_Z_valueChanged) self.doubleSpinBox_Z.setToolTip( _translate("MainWindow", "Sliding axis Z", None)) ypos = ypos + 40 # Make the interactive slider control # As you move this slider with the mouse, the cross-section slides # through the model self.label_5 = QtGui.QLabel(self) self.label_5.setGeometry(QtCore.QRect(margin, ypos, slw, 22)) self.label_5.setObjectName(_fromUtf8("label_5")) self.label_5.setText(_translate( "MainWindow", "Position along axis", None)) ypos = ypos + 30 self.horizontalSlider = QtGui.QSlider(self) self.horizontalSlider.setGeometry(QtCore.QRect(margin, ypos, slw-50, 20)) self.horizontalSlider.setOrientation(QtCore.Qt.Horizontal) self.horizontalSlider.setInvertedAppearance(False) self.horizontalSlider.setObjectName(_fromUtf8("horizontalSlider")) self.horizontalSlider.setRange(0, 100) self.horizontalSlider.setValue(int(self.fraction * 100.0)) self.horizontalSlider.setToolTip(_translate( "MainWindow", "Slide to move cross-section along axis", None)) # must be called after setValue() self.horizontalSlider.valueChanged.connect(self.on_horizontal_slider) ypos = ypos + 30 self.progressBar_1 = QtGui.QProgressBar(self) self.progressBar_1.setGeometry(QtCore.QRect(margin, ypos, slw-50, 23)) self.progressBar_1.setValue(int(self.fraction * 100.0)) self.progressBar_1.setOrientation(QtCore.Qt.Horizontal) self.progressBar_1.setAlignment(QtCore.Qt.AlignCenter) self.progressBar_1.setObjectName(_fromUtf8("progressBar_1")) self.progressBar_1.setToolTip(_translate( "MainWindow", "Percent position of cross-section", None)) ypos = ypos + 40 ################################## add self.SpinBox_PBar = QtGui.QSpinBox(self) self.SpinBox_PBar.setGeometry(QtCore.QRect(sbp+255, ypos-40, 45, 23)) self.SpinBox_PBar.setMinimum(0.0) self.SpinBox_PBar.setMaximum(100.0) self.SpinBox_PBar.setValue(int(self.fraction * 100.0)) self.SpinBox_PBar.setSingleStep(1) self.SpinBox_PBar.setObjectName(_fromUtf8("SpinBox_PBar")) self.SpinBox_PBar.valueChanged.connect(self.on_SpinBox_PBar_valueChanged) self.SpinBox_PBar.setToolTip(_translate( "MainWindow", "Sliding percent", None)) ################################# add # Select the display format for the cross-section # This button shows a wire line in the cross-section plane self.radioButton_1 = QtGui.QRadioButton(self) self.radioButton_1.setGeometry(QtCore.QRect(margin, ypos, slw, 20)) self.radioButton_1.setText(_fromUtf8("Outline")) self.radioButton_1.setChecked(True) self.radioButton_1.toggled.connect(self.onRadioButton) self.radioButton_1.setObjectName(_fromUtf8("radioButton_1")) self.radioButton_1.setToolTip(_translate( "MainWindow", "Make cross-section as wire outline", None)) ypos = ypos + 30 # Select the display format for the cross-section # This button shows a normal 3D display with everything above the # cross-section plane cut away self.radioButton_2 = QtGui.QRadioButton(self) self.radioButton_2.setGeometry(QtCore.QRect(margin, ypos, slw, 20)) self.radioButton_2.setText(_fromUtf8("Cut objects")) self.radioButton_2.setChecked(False) self.radioButton_2.toggled.connect(self.onRadioButton) self.radioButton_2.setObjectName(_fromUtf8("radioButton_2")) self.radioButton_2.setToolTip(_translate( "MainWindow", "Make cross-section as cut objects", None)) ################################## #Keep the sectional view self.CB_00 = QtGui.QCheckBox(self) self.CB_00.setText(_fromUtf8("Keep the sectional view")) self.CB_00.setGeometry(QtCore.QRect(margin+168, ypos-30, slw, 20)) self.CB_00.setObjectName(_fromUtf8("CB_00")) self.CB_00.setChecked(False) self.CB_00.setToolTip(_translate( "MainWindow", "Keep the sectional view or erase", None)) ################################## # Called at macro start up by initUI() def hideObjects(self): # Initialise the cross-section state variables self.startup_failed = False self.fraction = 0.5 self.axisX = 0.0 self.axisY = 0.0 self.axisZ = 1.0 self.cross_section_type = 1 # We must have something to do a cross-section on if App.ActiveDocument is None : QtGui.QMessageBox.warning(None, _translate("MainWindow", "Cross-section", None), _translate("MainWindow", "There is no Active Document\n" + "Create one and run this macro again.", None), QtGui.QMessageBox.Cancel, QtGui.QMessageBox.Cancel) self.startup_failed = True self.parent.destroy() # This will close the window else : # Make a list of the user's objects # WARNING!! # This list is persistent. We'll get confused if the user deletes or # adds objects while the macro is active self.oblist = App.ActiveDocument.Objects # Create the cross-section object self.cs = FreeCAD.ActiveDocument.addObject("Part::Feature", "Generated__cross-section") self.OriginalVisibilities = list() self.xmin = 1000.0 self.xmax = -1000.0 self.ymin = 1000.0 self.ymax = -1000.0 self.zmin = 1000.0 self.zmax = -1000.0 # n = 0 # for p in self.oblist: # stupid Python list has no length function # n = n + 1 ############################# Skip the <group object> ######################## # add b0 = [] for x0 in self.oblist: if str(x0) != "<group object>": b0.append(x0) self.oblist = b0 n = len(self.oblist) ############################################################################### # Make a list of the visible objects and make them invisible while # the macro is active # Also we compute the bounding box of the model for i in range(n): vis = self.oblist[i].ViewObject.Visibility self.OriginalVisibilities.append(vis) if vis : if self.oblist[i].TypeId != str("Drawing::FeatureViewPython") : # add self.oblist[i].ViewObject.Visibility=False b = self.oblist[i].Shape.BoundBox if b.XMin < self.xmin : self.xmin = b.XMin if b.XMax > self.xmax : self.xmax = b.XMax if b.YMin < self.ymin : self.ymin = b.YMin if b.YMax > self.ymax : self.ymax = b.YMax if b.ZMin < self.zmin : self.zmin = b.ZMin if b.ZMax > self.zmax : self.zmax = b.ZMax # Moan and give up if there is nothing to cross-section if self.xmax <= self.xmin \ or self.ymax <= self.ymin \ or self.zmax <= self.zmin : QtGui.QMessageBox.warning(None, _translate("MainWindow", "Cross-section", None), _translate("MainWindow", "There are no visible solid objects\n" + "Create some and run this macro again.", None), QtGui.QMessageBox.Cancel, QtGui.QMessageBox.Cancel) self.restoreObjects() self.startup_failed = True App.ActiveDocument.removeObject("Generated__cross_section") self.parent.destroy() # This will close the window else : # Trigger initial display self.updateAxis() # Called when macro is closed # Restore the original visibility of the user's objects # and destroy our cross-section object def restoreObjects(self): n = 0 for p in self.oblist: # stupid Python list has no length function n = n + 1 for i in range(n): self.oblist[i].ViewObject.Visibility = self.OriginalVisibilities[i] try: if self.CB_00.isChecked() == False: App.ActiveDocument.removeObject("Generated__cross_section") except Exception: None # Something has changed, recalculate the cross-section def updateGui(self): # default to no visible cross-ection self.cs.ViewObject.Visibility = False # check if the sliding axis is invalid if self.xdir == 0.0 and self.ydir == 0.0 and self.zdir == 0.0 : QtGui.QMessageBox.warning(None, _translate("MainWindow", "Cross-section", None), _translate("MainWindow", "The sliding axis has zero length\n" + "Please set a valid axis.", None), QtGui.QMessageBox.Ok, QtGui.QMessageBox.Ok) else : # First we compute the 0% and 100% positions on the sliding axis if self.xdir < 0.0 : x = self.xmax + self.fraction * self.xdir else : x = self.xmin + self.fraction * self.xdir if self.ydir < 0.0 : y = self.ymax + self.fraction * self.ydir else : y = self.ymin + self.fraction * self.ydir if self.zdir < 0.0 : z = self.zmax + self.fraction * self.zdir else : z = self.zmin + self.fraction * self.zdir r = 2 * max(self.xmax - self.xmin, self.ymax - self.ymin, self.zmax - self.xmin) # Display the dimensions dimDep = "X "+str(x)+" mm , Y "+str(y)+" mm , Z "+str(z)+" mm" App.Console.PrintMessage(dimDep + "\n") # Create a big enough disc in the cross-section plane c = Part.makeCircle(r, Base.Vector(x, y, z), Base.Vector(self.xdir, self.ydir, self.zdir)) f = Part.Face(Part.Wire(c)) l = list() # list for cross-section parts h = list() n = 0 for p in self.oblist: # stupid Python list has no length function n = n + 1 something = False if self.cross_section_type == 1 : # wire line cross-section for i in range(n): if self.oblist[i].TypeId != str("Drawing::FeatureViewPython") : # add if self.OriginalVisibilities[i] : ob = FreeCAD.ActiveDocument.addObject("Part::Feature") ob.ViewObject.DiffuseColor = self.oblist[i].ViewObject.DiffuseColor ob.Shape = self.oblist[i].Shape.section(f) # check for valid section part if ob.Shape.BoundBox.XMin <= ob.Shape.BoundBox.XMax : l.append(ob) something = True else: FreeCAD.ActiveDocument.removeObject(ob.Name) else : # cut shape cross-section # extrude our cross-ection disc into a cylinder cyl = f.extrude(Base.Vector(self.xdir, self.ydir, self.zdir)) doc = FreeCAD.ActiveDocument for i in range(n): if self.oblist[i].TypeId != str("Drawing::FeatureViewPython") : # add if self.OriginalVisibilities[i] : acut = doc.addObject("Part::Cut","Cut") abase = Draft.clone(self.oblist[i]) atool = doc.addObject("Part::Feature") atool.Shape = cyl atool.ViewObject.ShapeColor=(0.25,0.57,0.35) doc.recompute() acut.Base = abase acut.Tool = atool acut.ViewObject.DiffuseColor = abase.ViewObject.DiffuseColor doc.recompute() ob = doc.addObject("Part::Feature") ob.Shape = acut.Shape ob.ViewObject.DiffuseColor = acut.ViewObject.DiffuseColor doc.recompute() doc.removeObject(acut.Name) doc.recompute() doc.removeObject(abase.Name) doc.recompute() doc.removeObject(atool.Name) doc.recompute() if ob.Shape.isValid() and ob.Shape.Volume > 0.0 : l.append(ob) something = True else: doc.removeObject(ob.Name) if something : feature = FreeCAD.ActiveDocument.addObject("Part::Compound","Compound") feature.Links = l FreeCAD.ActiveDocument.recompute() if feature.Shape.isValid() : self.cs.Shape = feature.Shape.copy() self.cs.ViewObject.DiffuseColor = feature.ViewObject.DiffuseColor self.cs.ViewObject.Visibility = True for od in l: FreeCAD.ActiveDocument.removeObject(od.Name) FreeCAD.ActiveDocument.recompute() FreeCAD.ActiveDocument.recompute() FreeCAD.ActiveDocument.removeObject(feature.Name) FreeCADGui.updateGui() # User changed axis vector # Compute a new axis vector whose length just covers the model def updateAxis(self): ldir = 0.0 if self.axisX != 0.0 : ldir = (self.xmax - self.xmin) / abs(self.axisX) if self.axisY != 0.0 : ldir = max(ldir, (self.ymax - self.ymin) / abs(self.axisY)) if self.axisZ != 0.0 : ldir = max(ldir, (self.zmax - self.zmin) / abs(self.axisZ)) self.xdir = self.axisX * ldir self.ydir = self.axisY * ldir self.zdir = self.axisZ * ldir self.updateGui() # recalculate the cross-section def on_horizontal_slider(self, val): self.fraction = val / 100.0 self.progressBar_1.setValue(val) self.SpinBox_PBar.setValue(val) self.updateGui() def on_doubleSpinBox_X_valueChanged(self, val): self.axisX = val self.updateAxis() def on_doubleSpinBox_Y_valueChanged(self, val): self.axisY = val self.updateAxis() def on_doubleSpinBox_Z_valueChanged(self, val): self.axisZ = val self.updateAxis() def on_SpinBox_PBar_valueChanged(self, val): self.progressBar_1.setValue(val) self.horizontalSlider.setValue(int(val)) self.updateGui() def onRadioButton(self, wasChecked) : if self.radioButton_1.isChecked() : self.cross_section_type = 1 else : self.cross_section_type = 2 self.updateGui() ####################################### # Find FreeCAD's root window FreeCADRootWindow = Gui.getMainWindow() # Create the window and start it myWidget = CrossSectionWindow() # The CrossSectionWindow will do all the work
n = n + 1
>>> a_list = []
>>> a_list.append('a')
>>> a_list.append('b')
>>> a_list.append('c')
>>> len(a_list)
3
>>> type(a_list)
<type 'list'>
