Is this an interesting bug?
sliptonic
Post by sliptonic »
I was doing some work with sections and came across this edge case. Is this a known bug? Avoidable?
Open the attached file and select the shape. Then do a cross section at 10 mm. That's the level at which the flat section meets the cylinders.
That gives what looks like a good section. No errors in the console but selecting it shows something odd in the selection highlighting.
Then selecting it and "Part->Make Face from wires" creates a face but shows an error.
12:09:58  <Part> ViewProviderExt.cpp(1267): Cannot compute Inventor representation for the shape of facebug#Face: NCollection_Array1::Value
facebug.FCStd
(35.85 KiB) Downloaded 16 times
Re: Is this an interesting bug?
I cannot confirm here. This looks to me like one of those coplanar issues. What does CheckGeometry say?
OS: macOS 10.16
Version: 0.21.29997 (Git)
Hash: b52967d52ac46eff7c59e74d991f3f5b298944ef
Python 3.10.5, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
Locale: C/Default (C)
Installed mods:
  * FC_SU
  * FeedsAndSpeeds 0.4.0
  * fcgear 1.0.0
  * fasteners 0.3.51
  * sheetmetal 0.2.56
  * ExplodedAssembly
  * Curves 0.5.4
mfro
Post by mfro »
works fine for me as well
OS: Debian GNU/Linux bookworm/sid (GNOME/gnome)
Version: 0.21.30119 (Git)
Build type: Debug
Branch: attach_to_wire
Hash: f0e63ac5faded83da95352e69699e879c5bde360
Python 3.10.5, Qt 5.15.4, Coin 4.0.0, Vtk 7.1.1, OCC 7.7.0.dev
Cheers,
Markus
sliptonic
Post by sliptonic »
check geometry on the section shows no errors.
Check geometry after making a face from the wires shows errors.
OS: Linux Mint 20 (i3/i3)
Version: 0.21.30116 +1 (Git)
Build type: Unknown
Branch: littlefixes
Hash: 78df46b0f0039c67798080ec986c33f7083381bf
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.2
Installed mods:
  * Assembly4 0.12.3
  * Behave-Dark-Colors 0.1.1
  * 3DfindIT 1.2.0
  * ProDarkThemePreferencePack 1.0.0
  * sheetmetal 0.2.52
  * FeedsAndSpeeds
  * ExtremeProDark 1.0.4
  * FeedsAndSpeeds.bak
  * Dracula 0.0.2
wandererfan
Post by wandererfan »
sliptonic wrote: Tue Aug 16, 2022 5:18 pm I was doing some work with sections and came across this edge case. Is this a known bug? Avoidable?
The circles are duplicated in the cross section. If you explode the cross section, you will get 5 pieces instead of the expected 3. Choosing the outer boundary and two circles after exploding gives a good face.
facebug_exploded.FCStd
(43.45 KiB) Downloaded 10 times
sliptonic
Post by sliptonic »
wandererfan wrote: Tue Aug 16, 2022 7:35 pm
Ok. So is that a bug in the cross-section logic?
mfro
Post by mfro »
@sliptonic
compared to @chrisb's and my FreeCAD version, you seem to have a rather old OCC library in use.
Cheers,
Markus
I see the same 5 pieces when I explode the cross section.
wandererfan
sliptonic wrote: Tue Aug 16, 2022 7:41 pm Ok. So is that a bug in the cross-section logic?
I guess it is. You'd expect the section cut to deliver a prism where the top face has two extra wires for the circles, or a prism (without any circles) plus two faces for the circles. Here we get both the extra wire and the extra faces.
To deliver a trouble free result in this case, the cross section would have to check for duplicate wires in the result and drop them.
facebug_debug.FCStd
(41.32 KiB) Downloaded 10 times
mfro
Post by mfro »
sliptonic wrote: Tue Aug 16, 2022 5:18 pm Then selecting it and "Part->Make Face from wires" creates a face but shows an error.
Now we discuss a coplanar issue (which is not really surprising as we see that elsewhere as well).
The original post, however, objected about the error message (that I - and @chrisb don't see). Not the same thing.
Cheers,
Markus
