Best practices for organizing large python source tree
sliptonic
Post by sliptonic »
The Path tree is getting kind of unwieldy. We started out following the general guidelines in the wiki page.
/Mod/Path/
/App
/Gui
Most of the python ended up in the PathScripts sub-directory. Eventually as things grew, PostProcessors took on a life of its own. Then tools. Then unit tests. Then some 'common helpers'. etc. You get the idea. Now there's a lot redundancy in file names. We sometimes have problems with circular dependencies, and it's tough for new developers to ramp up.
We're starting to talk about reorganizing things to make it cleaner and avoid these problems.
I've looked around for guidance on managing large python source trees. I haven't found much. Most tutorials assume all the python is in one directory, give the same advice about naming conventions, and move on to talking about PEP8. Not terribly helpful. Anyone aware of better resources or books?
If the next version is really going to be a 1.0, I'd prefer to do this cleanup now.
heda
Re: Best practices for organizing large python source tree
Post by heda »
+1 for the initiative (although i have zero skin in the wb as such, and have never used it)
is not a structure very dependent upon how one for example makes the classes, intra-lib dependencies, etc.
circular dependencies is a pita though...
probably the best is to just take a glance at large known projects to see what they have done
or a small write up, not for large projects...
https://docs.python-guide.org/writing/structure/
so in the end probably a matter of taste.
regardless a complete outsider and amateur view
fwiw maybe the starting point should simply be a lower case "path"
as in
Mod/Path
Mod/Path/InitGui.py
Mod/Path/path/ # this is now effectively a lib name, i.e. corresponding to a pip install "path"
Mod/Path/path/foo # foo is then your first organising level in the lib
foo could be "generators", "commands", "gui", "operations", "tools" or what is needed for the wb.
imports could then be
from path import foo
or
import path.foo as pfoo
or, if foo has function bar in it
from path.foo import bar
note that this is almost like the draft remake, although imho they should have taken it one step further and instead of making for example
Mod/Draft/draftfunctions
it could have been
Mod/Draft/draft/functions
allowing for an import like
import draft.functions as dfunc
instead of
import draftfunctions as dfunc
this of course opens up for name clashing,
but that risk is imho there today anyways,
and if one uses for example pfunc and dfunc as alias, that clash-risk is mitigated...
