Example/Tutorial on using FreeCad logging from C++
CandL
Post by CandL »
I am trying to debug some C++ in the Path workbench.
I would like to be able to write to the FreeCad log file written to C:\Users\***\AppData\Roaming\FreeCAD using the command line: FreeCADCmd.exe -l --run-test 0
I think I want to use the Macros in Console.h, Are there examples/tutorials on using these?
What does not seem to work is:
#include <Base/Console.h>
Then in a method:
     FC_MSG("Path Command Obj init")
Sorry for all the noob questions but there is a lot to take in
wandererfan
Re: Example/Tutorial on using FreeCad logging from C++
Post by wandererfan »
CandL wrote: Sat Aug 06, 2022 5:47 pm FC_MSG("Path Command Obj init")
I think FC_MSG writes to the report view. You probably want FC_LOG to write to the log. If that doesn't do it, try something like this:
Base::Console().Log("myObject: %s  myLabel: %s\n", getNameInDocument(), Label.getValue());
CandL
Post by CandL »
That did it ... Thanks
