[answered] python max integer question
uwestoehr
Post by uwestoehr »
When I set an App::PropertyIntegerConstraint that was defined via Python to e.g
1e16
I get this error:
Python int too large to convert to C long
sys.maxsize gives me:
9.2e18
So why doIi get this error despite 1e16 is smaller than sys.maxsize?
I have:
OS: Windows 10 Version 2009
uwestoehr
Re: python max integer question
Post by uwestoehr »
To be precise, this is my code that fails:
solver.addProperty(
            "App::PropertyIntegerConstraint",
            "TimestepIntervals",
            "Timestepping",
            "Maximum optimization rounds if 'Simulation Type'\nis either 'Scanning' or 'Transient'"
            solver.TimestepIntervals = (100, 1, int(1e16), 1)
It also fails with int(1e12).
1e8 works.
mfro
Post by mfro »
Microsoft, in their ultimate wisdom, decided that a long with 32 bits in length would be long enough.
At least if you use the MSVC compiler.
Cheers,
Markus
uwestoehr
Post by uwestoehr »
mfro wrote: Fri Aug 05, 2022 4:28 pm Microsoft, in their ultimate wisdom, decided that a long with 32 bits in length would be long enough.
Thanks!
Googling now shows that also on 64bit Win and when compiling with 64bit as target, 32 bit is used. :o
mfro
Post by mfro »
uwestoehr wrote: Fri Aug 05, 2022 4:40 pm
Thanks!
If you want a 64 bit type on Windows (64), you have to use size_t.
Cheers,
Markus
