[Bug?] AppImage version of FreeCad can't use AppImage of OpenScad (and possible other externals)
gneiss
Re: [Bug?] AppImage version of FreeCad can't use AppImage of OpenScad (and possible other externals)
Post by gneiss »
OK, hopefully looo will see this and give me a hint...
In the meanwhile I had compiled Freecad.
Giving the instructions from https://wiki.freecadweb.org/Compile_on_Linux it works, even that I had to install a lot of extra (not mentioned there) packages (I compile unter Ubuntu 20.04.4 LTS, that's my fastet PC)
Compilation is done, now I try to understand the structure of the source tree.
Right now I don't see a "global" or "core" python-Module where my function CallExternalExecutable should go.
As I found there must be a Module FreeCAD, because this is imported from OpenSCAD, but there is no such Module-Dir in the src-tree.
There is a FreeCAD.so in the Build (under lib), but I don't now where to place my function so that is will be available inside a python script when "import FreeCAD" was performed.
Any help appreciated.
Post by Kunda1 »
What's the status of this thread? (...and it's relationship to issue #7182)
adrianinsaval
Post by adrianinsaval »
it seems the folk at cfdOF had a similar issue and implemented a workaround in the addon: https://gitlab.com/opensimproject/cfdof ... ss.py#L181
a general solution others can use would be ideal
gneiss
Post by gneiss »
As I mentioned before, I need some help in where to put my global function...
No hint given till now..
looo
Post by looo »
to create an AppImage you need to have conda/mamba installed. Best to install mambaforge:
https://github.com/conda-forge/miniforge
then do this steps in the FreeCAD-Bundle repo:
export DEPLOY_RELEASE=weekly-builds
cd conda/linux
bash create_bundle.sh
hope this helps
gneiss
Post by gneiss »
Sorry, no. As mentioned above, I have no idea where I should place a "global" (python) function..
It seams that freecad base isn't (real) python it's python written in C(++)
onekk
Post by onekk »
gneiss wrote: Wed Sep 14, 2022 1:32 pm Sorry, no. As mentioned above, I have no idea where I should place a "global" (python) function..
If you are not aware, there is this section of the wiki:
https://wiki.freecadweb.org/Developer_hub
Where you could find some informations for "developers", probably the best place to start.
In section "Modifying FreeCAD" you will find this page:
https://wiki.freecadweb.org/The_FreeCAD_source_code
That has this sentence.
The FreeCAD code is programmed mainly in C++, but relies heavily on Python.
Hope it helps
Regards
Carlo D.
- Various other stuffs.
adrianinsaval
@wmayer where in the source could a globally available python file be placed?
Founder
Post by wmayer »
What about Ext/freecad? If you put there a file myModule.py you can import with
from freecad import myModule
onekk
Post by onekk »
wmayer wrote: Thu Sep 15, 2022 9:51 am What about Ext/freecad? If you put there a file myModule.py you can import with
So in my case, with a conda install, the path should be?
/home/username/miniconda3/envs/fcenv-dev/Ext/freecad/
Regards
Carlo D.
