[Bug] #7304 - SCAD import broken with OpenSCAD version 2022.02.25.ai11146
gneiss
Post by gneiss »
I had some issues when using the AppImage Version of OpenSCAD from FreeCad (see https://github.com/FreeCAD/FreeCAD-Bundle/issues/127). After finding a workaround I found, that the never Version of OpenSCAD will produce the following errors when opening my scad file.
In general I found some more bugs. Here is a list:
Using a locally installed OpenSCAD (version 2021.01)
Errors:
1. whole object is rotated 90° around X-Axis
2. extra "lines" of Text (in Model)
3. extra "Layers (in Model)
Workaround:
1 Rotate Object after importing
2-3 can be eliminated by deleting these parts from Model-View
Using an AppImage of OpenScad (version 2022.02.25.ai11146 (git fb10c5dbf))
Errors:
1-3 as above
4 When used "linear_extrude( ... center = false ... )" or without parameter "center" inside the scad file:
File "/tmp/.mount_FreeCADfpAec/usr/Mod/OpenSCAD/importCSG.py", line 130, in open
processcsg(tmpfile)
File "/tmp/.mount_FreeCADfpAec/usr/Mod/OpenSCAD/importCSG.py", line 192, in processcsg
result = parser.parse(f.read())
File "/tmp/.mount_FreeCADfpAec/usr/lib/python3.10/site-packages/ply/yacc.py", line 333, in parse
return self.parseopt_notrack(input, lexer, debug, tracking, tokenfunc)
File "/tmp/.mount_FreeCADfpAec/usr/lib/python3.10/site-packages/ply/yacc.py", line 1120, in parseopt_notrack
p.callable(pslice)
File "/tmp/.mount_FreeCADfpAec/usr/Mod/OpenSCAD/importCSG.py", line 835, in p_linear_extrude_with_transform
if p[3]['center']=='true' :
<class 'KeyError'>: 'center'
Workaround:
1-3 as above
4 Use only "linear_extrude( ... center = true ... )" in SCAD-file
Bugfix:
1-3 I have no idea where so search inside the source code to fix this
4 in Generell it should be sufficient to use
p[3].get('center','false')
instead of
p[3]['center']
For this I already had created a pull request (see https://github.com/FreeCAD/FreeCAD/pull/7301)
For reference I attached the scad-file that produces the Error(s) the line that produces the error 4 is marked.
CR2032.scad
(918 Bytes) Downloaded 16 times
Reason: Added GH ticket number to thread title
adrianinsaval
Re: [Bug] SCAD import brocken with OpenSCAD version 2022.02.25.ai11146
Post by adrianinsaval »
@chennes I think you usually deal with openscad stuff? sorry for the noise if that is not the case
chennes
Post by chennes »
Yep -- I've been babysitting the OpenSCAD Workbench for the last year or two, so I'll add these to my radar. @gneiss when you have a moment please file (separate) bug reports on GitHub for each of these, and link back to this discussion. Thanks!
(I'll merge that PR once you've updated the commit title).
Chris Hennes
Pioneer Library System
gneiss
Post by gneiss »
@chennes:
That was my first idea, but there is a hint that requests to first start a discussion here. So I think You mean that this request is already fullfilled.
But now I am not sure, what You mean with "separate".
Should I make one for each of the errors 1-3 ?
gneiss
Post by gneiss »
OK, I had filed one report for error 1 and another one for 2&3.
My PR for bug 4 was already commited.
chennes
Post by chennes »
It's fine to have a single forum discussion for several related bugs, but in GitHub issues it's best to have only one issue per bug report because that way we can get GitHub to automatically close the bug when an appropriate commit is added.
Chris Hennes
Re: [Bug] #7304 - SCAD import broken with OpenSCAD version 2022.02.25.ai11146
Post by Kunda1 »
Added issue #7304 to title
