How do I translate these untranslated Words into Chinese?
oscarchan
Post by oscarchan »
I set global locale to Chinese but some of the properties still remain in English.
Is there a way I can translate this part through python console??
Thanks!
Thank you!
Re: How do I translate these untranslated Words into Chinese?
Check if these are available on crowdin. There takes the community effort place for the translation.
NewJoker
Post by NewJoker »
The current state of Chinese translation is:
- Chinese simplified: 61%
- Chinese traditional: 40%
You can help with translations on Crowdin, it will be appreciated for sure.
oscarchan
Post by oscarchan »
I am quite sure that these words are translated in Crowdin . But for unknown reason they don't get translated.
Thank you!
adrianinsaval
Post by adrianinsaval »
Correct me if I'm wrong but I think property names and property groups are not supposed to be translated to begin with, recently there was a discussion about removing the translation from that single group name that actually is translated. The rationale behind not translating these is that they are meant to be accessed through python too, and in python you have to use the original names, translations won't work.
david69
Post by david69 »
you're right adrianinsaval
adrianinsaval wrote: Sat Jul 09, 2022 12:27 am Correct me if I'm wrong but I think property names and property groups are not supposed to be translated
recently there was a discussion about the possibility to translate them but it raised some issues.
https://forum.freecadweb.org/viewtopic.php?f=10&t=69195
so for the moment, @oscarchan don't spend time on that, on reverse, it is better to keep them in English because they are used in the wiki pages as they are.
and welcome on board.
oscarchan
Post by oscarchan »
ok! Thank you guys.
Thank you!
