brainstorm: storage-efficient enums
Most objects created with the Arch WB have an IfcType App::PropertyEnum with more than 100 choices. When saving a FreeCAD file with many of these objects, the Document.xml becomes extremely large, mostly with repetitive enum stuff.
I'd like to implement a different kind of App::PropertyEnum that would avoid saving all these enums repeatedly...
I have two ideas:
1) The property doesn't store the enum values in the FCStd file. Instead, it has a py module + method stored, and, on restore, it would call that method to get the enum values. That would be kind of a module-dependent enum property. Problem: what if the module is not there?
2) The enum values are stored in a separate file in the .FCStd file. The enum property specifies a filename, creates the file on save if none is there, and all subsequent saves skip saving if the file exists. Problem: Not sure what happens if the file is already there from a previous file load...
Any other idea here? @wmayer ?
I have two ideas:
Re: brainstorm: storage-efficient enums
Maybe there could be a new subcategory of <SharedData> under <Document> within the Document.xml file, where this property of type="App::PropertyEnumeration" is saved once and referenced by the single object which uses this shared property. Kind of like IFC does it.
<?xml version='1.0' encoding='utf-8'?>
FreeCAD Document, see https://www.freecadweb.org for more information...
<Document SchemaVersion="4" ProgramVersion="0.20R29177 (Git)" FileVersion="1">
<Properties Count="15" TransientCount="3">
</Properties>
<SharedData Count="1"></SharedData> // <-- new subcategory for shared data blocks
<Objects Count="2" Dependencies="1">
</Objects>
<ObjectData Count="2">
</ObjectData>
</Document>
Based on my simplistic view that the complete content of each enum, is always available within FreeCAD code/module, why not only save current selected value of each enum in FCStd file?
Also is this only an IFC issue?
This is probably the right approach, as it addresses the cause of the excessive data duplication within a file, instead of just mitigating the symptoms. And it conforms to the single responsibility principle. An object should only know which IFCType it is derived from, not what other IFCTypes are available.spanner888 wrote: ↑Tue Jun 21, 2022 9:44 pm why not only save current selected value of each enum in FCStd file?
Another thing is, there is no used IFC schema specified within the FCStd file. There should be some property declaration stating if IFC2x3, IFC4 or (soon) IFC4x3 is used.
Edit/Add:
This holds for all other CustomEnumList as well, i.e. <Property name="PredefinedType" and <Property name="Align", which duplicate the corresponding enum lists for each object.
I think that need a pure enum property, which stores only the index
and uses a list of values from other properties.
You can declare the enum as transient property to avoid to save it to the XML file. Now all what you need is to save the index for each object independently and there you can override the __getstate__ and __setstate__ methods of your Python proxy class.
How do you fill the enum at the moment? Isn't it already implemented in a Python module to add the values?1) The property doesn't store the enum values in the FCStd file. Instead, it has a py module + method stored, and, on restore, it would call that method to get the enum values. That would be kind of a module-dependent enum property. Problem: what if the module is not there?
That's a really simple solution, thanks!! Can you make a transient property form Python? I didn't know...
At object init, yes. But you are right, of course that could also be ran at restore time! How silly I am
doc = App.newDocument()
obj = doc.addObject("Part::Feature", "Shape")
obj.addProperty("App::PropertyEnumeration", "Enumeration", "Base", "The enumeration property", App.PropertyType.Prop_Transient)
obj.Enumeration = ["Item1", "Item2", "Item3", "Item4", "Item5"]
Excellent, I'll use that.Thanks @wmayer !
