Missing "Const" attribute in xml
dpoen
Post by dpoen »
I might be misunderstanding the meaning of the "Const" in xml for the Python generation (for instance MatrixPy.xml).
I do understand it indicate that to object will not be changed. Correct ?
If so, should be more method received this attribute? For instance the inverse() method should be " Const="true", isn't it ?
I could do the fix, but I do need to know if I'm right,
OS: Debian GNU/Linux 11 (bullseye) (XFCE/xfce)
Version: 0.21.Unknown
Build type: Unknown
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.1
onekk
Re: Missing "Const" attribute in xml
Post by onekk »
dpoen wrote: Mon Jun 20, 2022 10:12 am Hello,
Internals of such things are known by few developers, @wmayer er is the most authoritative person" let's see if poking will make something happens.
wmayer wrote:
Hi and sorry for poking but I think this answer is know by very few people here.
Regards
Carlo D.
- Various other stuffs.
Founder
Post by wmayer »
Yes, that's correct.
There still might be functions where we forgot to add this attribute. And yes the inverse() method requires it, too.
I will add it. git commit 7de8a14b37
dpoen
Post by dpoen »
the methods multiply(), determinant(), isOrthogonal(), submatrix(), analyze() might also get the const attribute, is that correct ?
openBrain
Post by openBrain »
dpoen wrote: Wed Jun 22, 2022 12:05 pm the methods multiply(), determinant(), isOrthogonal(), submatrix(), analyze() might also get the const attribute, is that correct ?
I guess you can prepare a PR on GH. ;) @wmayer will likely check it there directly.
dpoen
Post by dpoen »
Yes, that work too xD
dpoen
Post by dpoen »
@wmayer, I have a question, which tool actually use those xml ? I expect that to be some sort of code generation stuff, but I can't find it ...
marioalexis
Post by marioalexis »
You will see the changes in the MatrixPy.xml file reflected in the MatrixPy.cpp and MatrixPy.h files in the build directory once you compile the program.
To see more details about the impact of the xml file tags, you can read src/Tools/generateTemplates/templateClassPyExport.py
dpoen
Post by dpoen »
Got it, that is what I was looking for, thank :)
adrianinsaval
Post by adrianinsaval »
@wmayer no clue if this is really related: https://forum.freecadweb.org/viewtopic. ... 10#p565791
but could it be that the function for obj.Shape.scaled is also missing this const attribute?
