Since the merge of https://github.com/FreeCAD/FreeCAD/pull/4556
we try to keep the UI files sorted.
However, the necessary script is not yet part of FreeCAD. Moreover David, the author of the script:
https://github.com/davidosterberg/Qt-UI-file-sorter
is sometimes not available because of family reasons. And now it turned out that the script is a bit over-eager with the "stdset=0" arguments when being used with its default settings.
Therefore I think the script should become part of FreeCAD and its defaults should be changed to work as we like it.
What do you think?
@chennes, since you kindly took care for the merge, would you take care here as as well and integrate the script if the others here agree?
integration of UI sorting script to FreeCAD
