CI the green hooks are not transfered from gitlab to github
from https://forum.freecadweb.org/viewtopic. ... 40#p559446
https://gitlab.com/freecad/FreeCAD-CI/-/commits/master
and
https://github.com/FreeCAD/FreeCAD/commits/master
as well as
https://gitlab.com/freecad/FreeCAD-CI/- ... eeCAD-0-19
and
https://github.com/FreeCAD/FreeCAD/comm ... eeCAD-0-19
if there is a green hook or a red cross on gitlab there should be one on github as well. I need to have a closer look at this.
and
as well as
and
Re: CI the green hooks are not transfered from gitlab to github
gitlab needs a access token to push the status updates to github. This github access tokes had been expired. I just regenerated the token. Let's see if the green hooks and red crosses will come back.
cheers bernd
cheers bernd
the hooks are back ...
as a reminder for me ...
the token will be expire on April the 7th thus needs to be recreated and be copied here on gitlab ... https://gitlab.com/freecad/FreeCAD-CI/- ... ithub/edit
I restarted the tests of all PRs which do not had the gitlab CI test result update because of the missing token. This will update the PullRequest check status on github for all PRs which do miss this check status.
bernd
bernd
restarted the tests on maser and master 019 too to get the missing CI updates back on these release branches even for older commits.
bernd
bernd
reminder ... This token expires on Sun, Jul 10 2022. To set a new expiration date, you must regenerate the token.
green hooks are back again ... reminder ... token expires on 30th of December 2022
- adrianinsaval
can't the token last longer? or do you make them short-lived on purpose for security? If so, isn't the token limited to only what's needed for the checkmarks? if so, do we really need that security measure?
Also github should send you an email to remind you when the token is going to expire.
90 day is the longest less than infinity, afaik, BUT I will check once again.adrianinsaval wrote: ↑Mon Oct 24, 2022 8:14 pm can't the token last longer? or do you make them short-lived on purpose for security? If so, isn't the token limited to only what's needed for the checkmarks? if so, do we really need that security measure?
