./FreeCAD -l -u ./usr.cfg -s ./sys.cfg
BUT the report pane shows:-
Loading Assembly4 WorkBench
connect failed: No such file or directory
So it appears that the above commandline does not provide a totally pristen clean FreeCAD environment.
Searching shows items below, which suggest the above should provide clean environment.
Start_up_and_Configuration
reeCAD_was_running_normally.2C_and_suddenly_it_doesn.27t_start_anymore
BOTH do NOT mention ~/.config/FreeCAD/FreeCAD.conf
How to completely reset FreeCAD
Re: How to completely reset FreeCAD
Postby triplus » Sun Oct 15, 2017 10:28 pm
there is one additional config file (on Ubuntu and likely in general on Linux) related to some aspects of the UX (Qt):
If I delete
and run ./FreeCAD -l -u ./usr.cfg -s ./sys.cfg&
If I delete both
~/.config/FreeCAD
Then all seems OK ie does not load style sheet AND Assembly4 WB.
So, the question is, do I now have a totally clean/default/pristine/factory reset FreeCAD environment?
Additionally should the two wiki pages linked above be updated?
