I'm not sure these commands make sense here, since as far as I know the measuring creation commands are defined in the Part Workbench, in src/Mod/Part/Gui/Command.cpp.
So, I think it would make more sense to move the commands to the Part Module. Actually, the same commands are implemented in the Part Module, they are, Part_Measure_Toggle_All and Part_Measure_Clear_All.
So the same commands are repeated, once in the base system, and once in the Part module. The ones in the base system are launched from the "View" menu, then "Visibility", and from the context menu of the 3D view, that is, by right-clicking and choosing "Measure".
The commands defined in the Part Workbench are instead launched from the "Measure" menu, and the "Measure" toolbar that are created in this workbench.
The icons used by the measure functions are in the Part directory, with the exception of the repeated commands which are in the core directory src/Gui. This is also a bit inconsistent.
src/Gui/Icons/
Part_Measure_Clear_All.svg
Part_Measure_Toggle_All.svg
src/Mod/Part/Gui/Resources/icons/
Part_Measure_Angular.svg
Part_Measure_Linear.svg
Part_Measure_Refresh.svg
Part_Measure_Step_Active.svg
Part_Measure_Step_Done.svg
Part_Measure_Toggle_3d.svg
Part_Measure_Toggle_Delta.svg
