FreeCADCmd is exited on quaitity without unit
bernd
Post by bernd »
from FreeCAD import Units
myquantity = Units.Quantity('500')
Units.Unit(myquantity)
I know it is wrong but FreeCADCmd exits !
hugo@Ahorn:~/build$ ./bin/FreeCADCmd
FreeCAD 0.19, Libs: 0.19R21276 (Git)
(c) Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
[FreeCAD Console mode <Use Ctrl-D (i.e. EOF) to exit.>]
Units.Unit(myquantity)>>> >>>
<Exception> Unit underflow in unit
hugo@Ahorn:~/build$
Is this correct bahaviour ?
OS: Debian GNU/Linux 10 (buster) (KDE//usr/share/xsessions/plasma)
Version: 0.19.21276 (Git)
Build type: Unknown
Branch: femtmp
Hash: bed6f9f61cbfbb330b8ea6f68439bb267da53b40
Python version: 3.7.3
Qt version: 5.11.3
Locale: German/Switzerland (de_CH)
Founder
Re: FreeCADCmd is exited on quaitity without unit
Post by wmayer »
bernd
Post by bernd »
great :D ... found another strange one ...
Units.Unit(Units.Quantity('500'))
Units.Unit(Units.Quantity('5'))
Units.Unit(Units.Quantity('-5'))
OverflowError: Unit underflow in unit
Unit: mm^5 (5,0,0,0,0,0,0,0)
Unit: 1/mm^5 (-5,0,0,0,0,0,0,0)
I would expect the first one for all number without unit, but this does not apply for floats from -7.9999 to 7.9999
Founder
Post by wmayer »
bernd wrote: Wed May 27, 2020 6:09 am found another strange one ...
Sorry, but what exactly is strange?
bernd
Post by bernd »
from Python Base.Unit docsting
Unit
defines a unit type, calculate and compare.
The following constructors are supported:
Unit()                        -- empty constructor
Unit(i1,i2,i3,i4,i5,i6,i7,i8) -- unit signature
Unit(Quantity)                -- copy unit from Quantity
Unit(Unit)                    -- copy constructor
Unit(string)                  -- parse the string for units
I only tested Unit(Quantity) and Unit(string)
q1 = Units.Quantity('500 MPa')
q1.Unit
Units.Unit(q1)
>>> q1.Unit
Unit: kg/(mm*s^2) (-1,1,-2,0,0,0,0,0) [Pressure]
>>> Units.Unit(q1)
OverflowError: Unit overflow in unit
IMHO the last line should return a Base.Unit.Pressure
q2 = Units.Quantity('500')
q2.Unit
Units.Unit(q2)
>>> q2.Unit
Unit:  (0,0,0,0,0,0,0,0)
>>> Units.Unit(q2)
IMO the last line should return a empty Base.Unit (like second line did)
q3 = Units.Quantity('5')
q3.Unit
Units.Unit(q3)
>>> q3.Unit
>>> Units.Unit(q3)
IMO the last line should return a empty Base.Unit (like second line did). Why does numbers from -7.999 to 7.999 return legth unit with the order of the first caracter of the provided string? 7 instead of 5 returns m^7, see next example ...
q4 = Units.Quantity('7')
q4.Unit
Units.Unit(q4)
>>> q4.Unit
>>> Units.Unit(q4)
Unit: mm^7 (7,0,0,0,0,0,0,0)
bernd
Post by bernd »
all together for simple copy paste ...
q1.Unit
Units.Unit(q1)
q2.Unit
Units.Unit(q2)
q3.Unit
Units.Unit(q3)
q4.Unit
Units.Unit(q4)
Founder
Post by wmayer »
git commit 24bb210a0
The problem was the order of checked types in UnitPy::PyInit. Since the QuantityPy supports the number protocol this line
    if (PyArg_ParseTuple(args, "|iiiiiiii", &i1,&i2,&i3,&i4,&i5,&i6,&i7,&i8)) {
handled the first identifier i1 which got its value from the quantity. That's why the length dimension always was so high.
bernd
Post by bernd »
:D even understood what was going wrong ...
>>> q1.Unit
>>> Units.Unit(q1)
>>> q2.Unit
>>> Units.Unit(q2)
>>> q3.Unit
>>> Units.Unit(q3)
>>> q4.Unit
>>> Units.Unit(q4)
