Are unit-tests enabled on travis-ci? Is this segfault normal/expected?
- wandererfan
Re: Are unit-tests enabled on travis-ci? Is this segfault normal/expected?
For the lazy among us:ezzieyguywuf wrote: ↑Thu Oct 24, 2019 12:11 am https://travis-ci.org/FreeCAD/FreeCAD/j ... 9636#L8663
testRemoval (Document.DocumentBasicCases) ... ok
testExpression (Document.DocumentExpressionCases) ... ok
testApplyFiles (Document.DocumentFileIncludeCases) ... Program received signal SIGSEGV, Segmentation fault.
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f7f331ccf20]
#1 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(PyArg_ParseTupleAndKeywords+0x63) [0x7f7f35469053]
#2 0x7f7f3603f1b3 in App::Application::sOpenDocument(_object*, _object*, _object*) from /usr/local/lib/libFreeCADApp.so+0x53
#3 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(_PyCFunction_FastCallDict+0x1bb) [0x7f7f35362eab]
#4 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(+0x21c393) [0x7f7f35437393]
#5 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(_PyEval_EvalFrameDefault+0x5170) [0x7f7f35402b70]
- wandererfan
And no, a segfault while running tests in Travis is not normal/expected.ezzieyguywuf wrote: ↑Thu Oct 24, 2019 12:11 am https://travis-ci.org/FreeCAD/FreeCAD/j ... 9636#L8663
I thought so. If the unit test fails, the Travis build should fail, right?wandererfan wrote: ↑Thu Oct 24, 2019 2:05 pmAnd no, a segfault while running tests in Travis is not normal/expected.ezzieyguywuf wrote: ↑Thu Oct 24, 2019 12:11 am https://travis-ci.org/FreeCAD/FreeCAD/j ... 9636#L8663
In this case, the seg fault caused no error. What’s more, I found a different build with a failing unit test in Path workbench , but the Travis build completed successfully.
- wandererfan
It looks as if the success/failure of the unit tests is based on return codes listed in a log file. Suspect the segfault in the test halts the program before the return code record is written to the log. The log checker doesn't see a bad return code, so it judges the tests to have all passed.ezzieyguywuf wrote: ↑Thu Oct 24, 2019 11:42 pm I thought so. If the unit test fails, the Travis build should fail, right?
Looks like a bug ticket is in order.
triplus wrote:ping!
sgrogan wrote:ping!
This is the first time I've seen this on Linux, it happens on Windows because we use SEH and the segfault is handled.
Bug report is good.
"fight the good fight"
- wandererfan
Until now we didn't try to fail the build if unit tests didn't pass. That should start to happen, once and if this PR gets merged:
https://github.com/FreeCAD/FreeCAD/pull/2729
BUT, now both Py3 (Clang/GCC) builds are failing, due to actually detecting the segmentation fault. ATM i don't know, if the segmentation fault happens due to toolchain or FreeCAD related issues.
Reference:
https://forum.freecadweb.org/viewtopic. ... 67#p349467
Reference:
Here we are talking about two different reasons for the crash. The issue mentioned by ezzieyguywuf was fixed more than two months ago and the reason was a missing flag for the sOpenDocument function of the Python binding to support keywords.ezzieyguywuf wrote: ↑Thu Oct 24, 2019 12:11 am https://travis-ci.org/FreeCAD/FreeCAD/j ... 9636#L8663
The new crash seems to happen more or less at program start and here are the first few lines of the call stack:
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f7a4aff2f20]
#1 /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0(Py_InitModule4_64+0x2b) [0x7f7a457772eb]
#2 /usr/lib/python3/dist-packages/PySide/QtCore.cpython-36m-x86_64-linux-gnu.so(PyInit_QtCore+0x4b) [0x7f7a2e4a54cb]
#3 /usr/lib/x86_64-linux-gnu/libpython3.6m.so.1.0(_PyImport_LoadDynamicModuleWithSpec+0x18c) [0x7f7a52c33dcc]
And what's also very strange is the cmake report before the build starts:
Summary report
-- Build type: Release
-- Compiler: /usr/local/clang-7.0.0/bin/clang++ (7.0.0)
-- Flags: -Wall -Wextra -Wpedantic -Wno-write-strings -Wno-undefined-var-template
-- Python: [/usr/bin/python3] []
-- PCL: not enabled
-- pybind11: not enabled
-- Boost: 106501
-- XercesC: [/usr/lib/x86_64-linux-gnu/libxerces-c.so] [/usr/include]
-- ZLIB: 1.2.11
-- PyCXX: [/home/travis/build/FreeCAD/FreeCAD/src]
-- OCC: 7.3.0 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBin;TKBool;TKBO;TKCDF;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEP;TKSTEPBase;TKSTEPAttr;TKHLR;TKFeat]
-- SMESH: build internal
-- MEDFile: [/usr/lib/x86_64-linux-gnu/libmedC.so] [/usr/include]
-- HDF5: 1.8.13
-- VTK: 7.1.1
-- NETGEN: not enabled
-- SWIG: 3.0.12
-- Eigen3 3.3.4
-- Qt4:
-- QtWebKit: found
-- Shiboken: 1.2.2 [/usr/include/shiboken]
-- PySide: 1.2.2 [/usr/include/PySide]
-- PySideTools: [/usr/bin/pyside-uic] [/usr/bin/pyside-rcc]
-- Freetype: 2.8.1
-- OpenGLU: /usr/lib/x86_64-linux-gnu/libGLU.so [/usr/lib/x86_64-linux-gnu/libGLU.so][/usr/include]
-- Coin3D: [/usr/lib/x86_64-linux-gnu/libCoin.so] [/usr/include]
-- SPNAV: [/usr/lib/libspnav.so] [/usr/include]
-- Matplotlib: 2.1.1
-- Rift: not enabled (BUILD_VR)
-- Doxygen: not found
Now run 'cmake --build /home/travis/build/FreeCAD/FreeCAD/build' to build FreeCAD
Looking at the build logs to see when the crashes appear it must have happened at November, 1st. With git commit 95f18a75 all is fine but with git commit 223d41c67 it uses the wrong libraries. For the commits in between the builds were cancelled so you can't see directly the culprit.
When looking at the code changes however I have identified the culprit to be: git commit 3d7b6b354eb1f
It's this line
because there are altogether three quotes and it looks like PYTHON_EXECUTABLE is set to Python3 and -DBUILD_FEM_NETGEN=ON -DBUILD_QT5=ON is used at program options. That's why CMake doesn't handle BUILD_QT5 any more.
This still doesn't explain the crash by introducing a Py2 library but that's a combination we never tested and thus I don't care about it.
It's this line
CMAKE_OPTS="-DPYTHON_EXECUTABLE="/usr/bin/python3 -DBUILD_FEM_NETGEN=ON -DBUILD_QT5=ON"
