I defined a shape of wire and a shape of face.
I want to get the shape by using makePipe.
But the final shape is weird.What's wrong with it?
The shape generated by makepipe is weird.
- LineAndArea.png (2.78 KiB) Viewed 760 times
- finalShape.png (2.11 KiB) Viewed 760 times
Re: The shape generated by makepipe is weird.
No FreeCAD info, no file attached, no exact step by step description - how can we help? Perhaps you can try to find a solution here: http://cdn2.spiegel.de/images/image-730 ... -73031.jpg
Sorry, it's my fault. I just posted my code.chrisb wrote: ↑Sat May 25, 2019 8:00 am No FreeCAD info, no file attached, no exact step by step description - how can we help? Perhaps you can try to find a solution here: http://cdn2.spiegel.de/images/image-730 ... -73031.jpg
class ConformalArea:
def __init__(self, obj):
obj.addProperty("App::PropertyVectorDistance", "Point1", "Object of a ConformalArea",
"Point1 of the ConformalArea").Point1 = FreeCAD.Vector(0.86, 0.5, 0)
obj.addProperty("App::PropertyVectorDistance", "Point2", "Object of a ConformalArea",
"Point2 of the ConformalArea").Point2 = FreeCAD.Vector(0.86, 0.5, 2)
obj.addProperty("App::PropertyAngle", "starAngle", "", "").starAngle = 30
obj.addProperty("App::PropertyAngle", "endAngle", "", "").endAngle = 90
obj.addProperty("App::PropertyFloat","Radius","","").Radius = 1
obj.Proxy = self
def execute(self, fp):
line = Part.makeLine(fp.Point1, fp.Point2)
linePath = Part.makeCircle(fp.Radius + 0.001, FreeCAD.Vector(0, 0, fp.Point2.z), FreeCAD.Vector(0, 0, 1),
fp.starAngle, fp.endAngle)
path = Part.Wire(linePath)
fp.Shape = path.makePipe(line)
class Line:
def __init__(self,obj):
obj.addProperty("App::PropertyVectorDistance", "Point1", "Object of a ConformalLine","Point1 of the ConformalLine").Point1 = FreeCAD.Vector(0.86, 0.5, 0)
obj.addProperty("App::PropertyVectorDistance", "Point2", "Object of a ConformalLine","Point2 of the ConformalLine").Point2 = FreeCAD.Vector(1.7, 1, 0)
#obj.addProperty("App::PropertyVectorDistance", "Point1", "Object of a ConformalLine","Point1 of the ConformalLine").Point1 = FreeCAD.Vector(0, 0.5, 0)
#obj.addProperty("App::PropertyVectorDistance", "Point2", "Object of a ConformalLine","Point2 of the ConformalLine").Point2 = FreeCAD.Vector(2, 1, 0)
obj.Proxy = self
fp.Shape=Part.makeLine(fp.Point1,fp.Point2)
obj1 = FreeCAD.ActiveDocument.addObject("Part::FeaturePython","ConformalArea")
ConformalArea(obj1)
obj1.ViewObject.Proxy=0
FreeCAD.ActiveDocument.recompute()
obj2 = FreeCAD.ActiveDocument.addObject("Part::FeaturePython","Line")
Line(obj2)
obj2.ViewObject.Proxy=0
path=Part.Wire(obj2.Shape)
obj=path.makePipe(obj1.Shape)
Part.show(obj)
- MyShape.png (8.64 KiB) Viewed 699 times
At the end of your script :
Here, obj1.Shape is a shell.
You should explicitly use a wire or an edge:
obj=path.makePipe(obj1.Shape.Wires[0])
Thank you very much.It is normal.But why is this shape not closed?Chris_G wrote: ↑Mon May 27, 2019 12:54 pm At the end of your script :Here, obj1.Shape is a shell.Code: Select all
You should explicitly use a wire or an edge:Code: Select all
- Shape.png (1.89 KiB) Viewed 673 times
When I use the makePipeShell function, why are some models closed and some models not closed?JOE_FU wrote: ↑Mon May 27, 2019 1:05 pmThank you very much.It is normal.But why is this shape not closed?Chris_G wrote: ↑Mon May 27, 2019 12:54 pm At the end of your script :Here, obj1.Shape is a shell.Code: Select all
