[REOPEN] [SOLVED] How to disable input value change with scroll wheel?
Re: [REOPEN] [SOLVED] How to disable input value change with scroll wheel?
Post by Kunda1 »
Re-opening this issue since there is a report that it still persists on macOS
issue #7532
CC testers: @ipatch @chrisb
Ognian
Post by Ognian »
I'm the one who reported the issue on the github tracker. I'm now also in this forum and get notifications on this thread...
openBrain
Post by openBrain »
Ognian wrote: Wed Oct 05, 2022 11:18 am I'm the one who reported the issue on the github tracker. I'm now also in this forum and get notifications on this thread...
Hmmm. Did you create the "General/ComboBoxWheelEventFilter" parameter switch and set it to "True" as explained in https://wiki.freecadweb.org/Fine-tuning#Mouse_related :?:
Then a restart is needed.
EDIT : forgot about that, I read the ticket !
The ticket lack precision. Are we talking about property editor, or something else ? May we have a screencast ?
Ognian
Post by Ognian »
Yes, I did this. Additionally I deleted FreeCad and all settings.
And afterwards reinstalled latest FreeCad without adding any mods. Then only created the key, set to true; restarted and unfortunately scrolling with the mouse changes values in the ComboBoxes ... (to test, go to part WB create Line, and scroll down to Length or Angle ComboBox; scroll changes values... )
openBrain
Post by openBrain »
OK. What I thought. We are not talking about Property Editor.
Ognian wrote: Wed Oct 05, 2022 1:02 pm (to test, go to part WB create Line, and scroll down to Length or Angle ComboBox; scroll changes values... )
Part WB has no such things. Draft WB ?
openBrain
Post by openBrain »
OK, got it.
So the "ComboBoxWheelEventFilter" switch works correctly on combo and spin boxes.
It doesn't work on Gui::InputField, which is the widget type you can find in Draft/CreateLine or similar.
Ognian
Post by Ognian »
Bildschirmaufnahme (FreeCAD-0.21-30486).gif (875.13 KiB) Viewed 678 times
here it is
Ognian
Post by Ognian »
Ok our updates on this crossed; So you are saying that there is no switch to disable this behavior? The screencast I did is with the actual Problem the window part in arch WB; You can see when I want to change the properties and scroll down it changes randomly fields...
This makes the workflow pretty unusable on a mac... Any Idea for a different workflow where this is no problem?
openBrain
Post by openBrain »
Ognian wrote: Wed Oct 05, 2022 1:21 pm So you are saying that there is no switch to disable this behavior?
That's it
I don't think it's different on Windows or Linux
No. But we can improve the code.
openBrain
Post by openBrain »
Here is a PR : https://github.com/FreeCAD/FreeCAD/pull/7561
I really can't understand the mess with Qt FocusPolicy that basically does nothing...
