[REOPEN] [SOLVED] How to disable input value change with scroll wheel?
IMHO, it's a dangerous decision for an engineering application to let the user change a numerical input value with mouse scroll wheel, because a value might be accidentally changed while scrolling in the property window.
How can we disable the "scroll to change" behaviour for all inputs?
Assembly 3 notes: https://github.com/ceremcem/freecad-notes
Re: How to disable input value change with scroll wheel?
This has hapened to me several time, while I hardly use the scroll function. However, I'm afraid that this is some Qt standard inheritance.
This was discussed by core developers in 2011: https://www.freecadweb.org/tracker/view.php?id=377
I believe Qt would provide some mechanism to override this behavior (like this), so I guess this is totally a task of FreeCAD.TheMarkster wrote: ↑Fri Sep 07, 2018 6:10 pm This was discussed by core developers in 2011: https://www.freecadweb.org/tracker/view.php?id=377
I think this may lead even more serious issues since we are not able to use "git diff" like verification mechanism to detect any accidental data changes.
I think there are ways provided by Qt. I searched for it after reading your post, and found something related to event filters and subclassing. I'm not sure about it being totally a task of FreeCAD. Generally, applications should not go about modifying the way system-wide components behave, absent some need unique to that application for doing so.
By the way, I also find the behavior to be both a blessing and a curse at different times. It's a very convenient way to change the value of a property, especially if the value you want falls on a whole number integer value, but it's annoying when it happens by accident. I think a better implementation would be to require shift+scroll (or similar) to change the contents.
I was thinking exactly the same: I would define this behavior as "a controlled version of scroll to change the value", thus I thought Ctrl+scroll. But anything other than a simple scroll would suffice.TheMarkster wrote: ↑Fri Sep 07, 2018 8:38 pm I think a better implementation would be to require shift+scroll (or similar) to change the contents.
Not sure, but I think this is C++ http://doc.qt.io/archives/qt-4.8/qspinbox.html I don't think we use Qtquick.
Never said this before, but this should probably be moved or transition the discussion to the Developers sub-Forum.
"fight the good fight"
- wandererfan
I'm in the curse camp, I'm afraid. I change values with the scroll wheel by accident far more often than on purpose.TheMarkster wrote: ↑Fri Sep 07, 2018 8:38 pm By the way, I also find the behavior to be both a blessing and a curse at different times. It's a very convenient way to change the value of a property, especially if the value you want falls on a whole number integer value, but it's annoying when it happens by accident. I think a better implementation would be to require shift+scroll (or similar) to change the contents.
<technobabble>
Gui::QuantitySpinBox and Gui::UIntSpinBox have FocusPolicy = Qt::WheelFocus by default. The problem can be partly solved by setting the FocusPolicy to Qt::StrongFocus instead. Here is a discussion from stackoverflow about handling this situation.
The code changes would be in /Gui/propertyeditor/PropertyItem.cpp, but I don't know the ramifications of setting StrongFocus everywhere.
</technobabble>
@wmayer or somebody else familiar with the property editor would have to pass judgement on this one.
Re: [SOLVED] How to disable input value change with scroll wheel?
@realthunder has solved the issue. Currently it seems it's safer to navigate in the property window.
