In our Version numbers (0.vv.gggg), where does the gggg come from (other than Help>AboutFreeCAD)? Is this number available via a git command? Is it stored in a .h file? Generated at build time? Is there a way to reference commit to gggg or vice versa?
Thanks,
wf
Version Number Explained?
- wandererfan
Re: Version Number Explained?
My GrabCAD FreeCAD-Projects
Native german speaker - so apologies for my english, no offense intended
This scipt is run by Cmake https://github.com/FreeCAD/FreeCAD/blob ... ubWCRev.pywandererfan wrote:In our Version numbers (0.vv.gggg), where does the gggg come from (other than Help>AboutFreeCAD)? Is this number available via a git command? Is it stored in a .h file? Generated at build time? Is there a way to reference commit to gggg or vice versa?
It creates ..builddir/src/build/version.h
After compile it is available by python
import FreeCAD
print(FreeCAD.Version()[:3])
print(FreeCAD.Version()[2])
"fight the good fight"
- wandererfan
So if I want to know the version as of a past commit, I
- check out the commit
- make a branch from the detached commit
- make a new build directory & build?
This will give me the same vv.gggg?
Only need to cmake, But this is not practical. We need to count from the hash of a commit. Should be be possible with a git command, as you originally asked. Relevant part of the script is here:https://github.com/FreeCAD/FreeCAD/blob ... ev.py#L178wandererfan wrote:- make a new build directory & build?
I'll try to understand the "git rev-list --count" part.
git checkout `git log origin/master --oneline --reverse --format=format:%H |head -n [color=#FF0000]6707[/color] |tail -n 1`
you might need to use "upstream" or whatever you called "blessed" to use shoogen's terms.
Thanks,
wf
[przemo@localhost freecad]$ git rev-list --count HEAD
10659
- wandererfan
This works perfectly! Thanks.PrzemoF wrote:Code: Select all
[przemo@localhost freecad]$ git rev-list --count HEAD 10659
