coil spring and helix
Werner added into PartDesing/Scripts Spring and Epitrochoid examples I see...
Re: Show your FreeCAD projects here!
I just checked it out (as in both svn and literally ) and they are coolkwahooo wrote:Werner added into PartDesing/Scripts Spring and Epitrochoid examples I see...
Jim
Full credit to the Kwahooo spring, this is an example of how easy it is to extend/modify something after someone has done all the hard work of creating the first version.
I have made a loop of pipe by creating two springs and subtracting one from the other.
Jim
A jpeg, just delete ".notreallyzipped.zip"....
Jim
from __future__ import division # allows floating point division from integers
import FreeCAD, Part
from FreeCAD import Base
class MySpring:
def __init__(self, obj):
''' Add the properties: Pitch, Diameter, Height, BarDiameter '''
obj.addProperty("App::PropertyLength","Pitch","MySpring","Pitch of the helix").Pitch=5.0
obj.addProperty("App::PropertyLength","Diameter","MySpring","Diameter of the helix").Diameter=6.0
obj.addProperty("App::PropertyLength","Height","MySpring","Height of the helix").Height=5.0
obj.addProperty("App::PropertyLength","BarDiameter","MySpring","Diameter of the bar").BarDiameter=3.0
obj.Proxy = self
def onChanged(self, fp, prop):
if prop == "Pitch" or prop == "Diameter" or prop == "Height" or prop == "BarDiameter":
self.execute(fp)
def execute(self, fp):
pitch = fp.Pitch
radius = fp.Diameter/2
height = fp.Height
barradius = fp.BarDiameter/2
myhelix=Part.makeHelix(pitch,height,radius)
g=myhelix.Edges[0].Curve
c=Part.Circle()
c.Center=g.value(0) # start point of the helix
c.Axis=(0,1,0)
c.Radius=barradius
p=c.toShape()
section = Part.Wire([p])
makeSolid=1 #change to 1 to make a solid
isFrenet=1
myspring=Part.Wire(myhelix).makePipeShell([section],makeSolid,isFrenet)
fp.Shape = myspring
class MySpringid:
obj.addProperty("App::PropertyLength","Pitch","MySpringid","Pitch of the helix").Pitch=5.0
obj.addProperty("App::PropertyLength","Diameter","MySpringid","Diameter of the helix").Diameter=6.0
obj.addProperty("App::PropertyLength","Height","MySpringid","Height of the helix").Height=5.0
obj.addProperty("App::PropertyLength","BarBore","MySpringid","Bore of the bar").BarBore=2.0
obj.Proxy = self
def onChanged(self, fpid, prop):
if prop == "Pitch" or prop == "Diameter" or prop == "Height" or prop == "BarBore":
self.execute(fp)
def execute(self, fpid):
pitch = fpid.Pitch
radius = fpid.Diameter/2
height = fpid.Height
barboreradius = fpid.BarBore/2
cid=Part.Circle()
cid.Center=g.value(0) # start point of the helix
cid.Axis=(0,1,0)
cid.Radius=barboreradius
pid=cid.toShape()
sectionid = Part.Wire([pid])
isFrenet=1
myspringid=Part.Wire(myhelix).makePipeShell([sectionid],makeSolid,isFrenet)
fpid.Shape = myspringid
def makeMySpring():
doc = FreeCAD.activeDocument()
if doc == None:
doc = FreeCAD.newDocument()
spring=doc.addObject("Part::FeaturePython","My_Spring")
spring.Label = "My Spring"
MySpring(spring)
spring.ViewObject.Proxy=0
def makeMySpringid():
if doc == None:
springid=doc.addObject("Part::FeaturePython","My_Springid")
springid.Label = "My Springid"
MySpringid(springid)
springid.ViewObject.Proxy=0
if __name__ == "__main__":
makeMySpring()
makeMySpringid()
#App.ActiveDocument.recompute()
App.activeDocument().addObject("Part::Cut","Cut")
App.activeDocument().Cut.Base = App.activeDocument().My_Spring
App.activeDocument().Cut.Tool = App.activeDocument().My_Springid
Gui.activeDocument().hide('My_Spring')
Gui.activeDocument().hide('My_Springid')
Gui.activeDocument().Cut.ShapeColor = Gui.activeDocument().My_Spring.ShapeColor
the kwahoo spring will become famous in history, a bit like the pythagore theorem or the columbus egg... Generations of students will study it and try to reproduce
Thanks, I added the aeroponics screenshot to the wiki. I forgot to give you credits in the file's comments though, sorry for that.casper-nilsson wrote:Sure its ok to use them, but reupload it to sourceforge, since its a dropbox link, you never know how long it will be in my folder.
On what distro are you and what theme/mod do you use? The wheel with bearing screenshot you posted on Wikimedia has me intrigued, with the tabs at the top of the screen!
I have to say your screenshots all look amazing. You have an eye for presentation/render.
Thanks for the color gradient, I'll try it out.
Re: coil spring and helix
I'm trying to use this script to do some coil springs. However, it isn't perfect. When you decrease the pitch, some surfaces are missing (try 2 mm for example), and below 5 mm, it never starts with a vertical circular cross section, instead the half top part of the starting point is missing. Is there a newer more refined script for coil springs ? Thanks.
Nevermind, I found my mistake, didn't realize it was a substraction of the 2.
